Front Brakes staying on
OK, after ALL the headaches I've had with the brakes on this car AND after finally getting a hard pedal , and "thinking" I have conquered the Brake problems....I still have run into a brick wall.
I took the car for a 3 mile ride yesterday, while returning to the house, I felt a drag on the front brakes. By the time I pulled into my garage the fronts were almost locking up...obviously not releasing. My light also comes on now every time I start the car, I hit the brake pedal and it goes out.
Everything on this car's brake system is new except the valve/switch.
Either my Rod is too long/short(HA,HA), between the master and booster or there is air in the system or my valve is no good.
BRAKE GURU'S please advise.
+1. If they don't release, loosen the lines to the MC and if fluid gushes out and the brakes release, you could have a bad MC (this was my case). the fact your brakes are dragging does not indicate a bad switch for your lights being on, somethings not right in the hydraulic. I would also check the distribution block as well.
don't forget about swollen rubber brake lines ......the rubber lines actually swell and under pressure the fluid goes through them and applies the brakes and then the swollen rubber lines act as a one way check valve and dont let the brakes retract
Received 3,179 Likes
I had this problem on one of the rear lines, looked perfect from the outside (like new) but was all cracked on the inside. When you put the brake on the fluid pushed all of the little bits open and then they would flop back closed and not let the fluid back out, but not every single time.
With the brake stuck on I started cracking line fittings until it released and then took of the flex hose, you could stick a coat-hanger through it one way and not the other.
New flex lines all around and moved on.
Mooser
