68 big block fly-wheel.......
Old Jul 20, 2011 | 05:06 PM
Kerrmudgeon's Avatar
Kerrmudgeon
C1 of Year Finalist (appearance mods) 2019
Default 68 big block fly-wheel.......
We want a stock steel flywheel for this build and the General doesn't list it anymore. Can I get a recommendation on a USA built quality steel unit. Got all the pros and cons on aluminum and will stick with the old steel one. They should be used on other GM cars/years as well right? Thanks.
Old Jul 20, 2011 | 05:27 PM
...Roger...'s Avatar
...Roger...
There's a 3856579 on ebay for $125
Old Jul 20, 2011 | 05:34 PM
redvetracr's Avatar
redvetracr
427" or 454"
Old Jul 20, 2011 | 06:55 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
like RedVetracr said "427 or 454" makes a differance,
Internal or External balance Flywheel.
Old Jul 21, 2011 | 10:16 AM
Kerrmudgeon
Sorry guys, it's an externally balanced 454 (1979 block).
Old Jul 21, 2011 | 01:21 PM
redvetracr's Avatar
redvetracr
interested in a GM #3973457 (externally balanced 454" flywheel) send a PM if you or anyone else is interested.
Old Jul 21, 2011 | 01:56 PM
zwede's Avatar
zwede
3993827 is available. Probably made in Mexico these days, but still a quality piece.
Old Jul 21, 2011 | 02:31 PM
Kerrmudgeon
which of these is the "correct one" or....what's the difference???
Old Jul 21, 2011 | 02:48 PM
redvetracr's Avatar
redvetracr
how would you like me to respond? you don`t accept PM`s
Old Jul 21, 2011 | 08:36 PM
Kerrmudgeon
I tried to change that, guess it didn't work. Will leave my email on a PM.
Old Jul 22, 2011 | 08:56 AM
69 Chevy's Avatar
69 Chevy
Are these OEM GM flywheels with the casting numbers, cast iron or cast steel?
Old Jul 22, 2011 | 01:17 PM
oldsarge's Avatar
oldsarge
I have one from a 73 454 auto, if interested ????
Old Jul 25, 2011 | 09:43 AM
Kerrmudgeon
Thanks Brian, but that would be the thin ring gear for an automatic right? I need the thick heavy *****! about 35 lbs.
Old Jul 25, 2011 | 09:48 AM
zwede's Avatar
zwede
3993827 is cast iron. I weighed it at 29 lbs, although the catalogs list it at 22.
To 68 big block fly-wheel.......
