Steering Box Lubrication
Old Apr 26, 2002 | 02:29 PM
Mike73's Avatar
Mike73
Default Steering Box Lubrication
What is the correct way to lube the steering gear box? Mine is manual steering, there doesn't seem to be a grease zerk visible, do you need to take the top cover off and pack grease in it ? If so, is there a chance to mess up any of the steering mechanism ?
Old Apr 26, 2002 | 02:37 PM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: Steering Box Lubrication (Mike73)
Remove rear cover bolt and the inner bolt, fill through the hole of rear bolt till it pours out of the other hole.
I use gearlube in my steeringbox
Marck
Old Apr 26, 2002 | 02:41 PM
One GM A Tech's Avatar
One GM A Tech
Old Apr 26, 2002 | 05:32 PM
Jim Shea's Avatar
Jim Shea
Default Re: Steering Box Lubrication (Twinnie)
A good lithium based chassis (ball joint) grease is recommended. Just fill through the side cover bolt holes. Do not try and fill the box 100%. You need some air space inside the gear box for the grease to expand when things get warm underhood.
To Steering Box Lubrication
