I have searched long and hard and can't quite find the correct wiring info, so I apologize in advance for asking redundant questions.
1971 vette with Ammeter, but will be switching to Voltmeter.
1) I have a brown 12v switched wire and a black/white constant 12v wire that went into the side of the alternator. Is it the switched 12v wire that connects to the "L" wire on the CS plug?
2) As far as I know, I don't have a generator/alternator light because I have an Ammeter. Is this a correct assumption and therefore, I will need to add a resistor?
Well heck, while searching something else, I believe I stumbled across the answer to #1 which is yes, I use the brown switched wire to the "L" connection.
Still not 100% sure on resistor, but thinking I should just do it to be safe.
Try using this to figure out your adapter. Follow the guidance as written. Worked the first time for me. Go to your local parts store and get the equivalent pigtail part number:
The site below tells you how to figure out which adapter to buy for your CS-144 tie in to your 12SI: I also added the key paragraph below in case you cannot open it.
"If you are unsure which adapter to use, measure the resistance of the exciter line. Disconnect the positive battery cable and the alternator plug. Connect an ohm meter between the #1 terminal on the plug end of the alternator harness and the end of the positive battery cable. Turn the ignition key to the "on" position and read the ohmmeter. If resistance is less than 35 ohms, use adapter #8078. If it’s between 35-350 ohms, use #8077. If it’s more than 350 ohms, you have excessive resistance somewhere in that circuit which needs to be repaired, first."
Checked the resistance as described and I currently have 41 ohms. The instructions state that a 50 ohm resistor should be used. Gonna give this a shot. Let's hope I don't blow this baby in 6 months...
I first converted my 10Si to a 94 Amp 12 Si....when I went to the CS-144 I just got the adapter. Being paranoid I figured that if I ever needed an alternator I could then get a 12Si or CS-144 and either would plug right in if I had the adapter.
[QUOTE=71_S-Ray;1578214047]I have searched long and hard and can't quite find the correct wiring info, so I apologize in advance for asking redundant questions.
YES The constant wire maybe able to leave disconnected as many CS144 alts have a internal reg sense jumper, making it redundant....
that black white wire goes to a piece of resistance wire, going to the switched say ignition circuit .....now to replace with a red 'idiot light'.....you just add a 159 bulb...or like I did a lo current bulb from Radio shack, and jumper a 220 ohm resistor across that bulb....gives the alt a bit more kick, stays charging at idle....
