Power Steering Cylinder Seal ??
Is it possible to replace that seal only by unbolting the ram from the frame and removing the snap ring from inside the bore? I am interested in doing it without removing it from the car. Will the seal pop out after the snap ring is removed?
Thanks,
Dan
http://www.cssbinc.com/images/ads/ho...r_for_1963.pdf
and the kit I used
http://www.cssbinc.com/1963-82powers...ebuildkit.aspx
and the kit I used
It sounds a little messy but they remove the snap ring ,start the car,turn the wheel and blow the seal assembly out,shut off the engine,remove the ram shaft from the frame,slide off the seals,clean and replace with new. Sounds pretty simple.
