Fuel problems - Vapor Lock ??
Old Jul 24, 2011 | 07:56 AM
mtedrick's Avatar
mtedrick
4th Gear
Default Fuel problems - Vapor Lock ??
I have a 1978 L82 that is having fuel deliver problems. After it runs for a 1/2 hour or so and gets warm, it will stall. I was driving along at 25 mph, it sputtered for a second then just died. It won't start again until it cools off. Yesterday after this occured, I put gas directly into the carb then it start and ran fine. I have had the car for 21 years and have never had this problem until recently so I assumed it was electrical and not vapor lock. I replaced the distributor cap, rotor, condenser, and control module but it didn't help. The fuel lines are where they've always been so I don't think it's vapor lock problem. What should I try next? Replace the fuel pump...if so, should I go electric? Or could it be a carb problem?
I doubt it has an impact on the problem but....the last thing I changed on the car before this problem started was taking out the original air intake and replacing with a K&N filter.
Old Aug 20, 2011 | 02:38 PM
mtedrick's Avatar
mtedrick
4th Gear
I replaced the fuel pump...problem solved.
