Starter motor cables
In the process of replacing the oil pan for a nice chrome job, I noticed that the cables coming from the starter look very tired.
They look like heavy duty cables.
2 questions
Where do they go to and are they easy to replace?
It's a 1971 454 LS5
Thanks in advance
Paul
Last edited by ashy2222; Jul 25, 2011 at 07:11 AM. Reason: missed off car and year
Your main battery cable goes back in the transmission tunnel, over the transmission, and up into the battery box behind the driver seat. It is secured along the way with cable clamps (about six or eight of them), along the way. I have changed a 1972 4 speed Corvette, and a 1981 4 speed Corvette, battery cable while the transmissions were still in the cars, so it is doable, but not fun.
Your other wire connections (harness), travel up the firewall, to a connector, the whole harness being about 18" long, secured in a metal tube, fastened to, I believe the cylinder head.
I would recommend that you make your own 'main power' cables, as the parts store ready-made stuff is cheap junk. If you can find a full-service parts store that makes their own cables, great. Otherwise, get some 4 awg copper-stranded wire at Lowe's or Home Depot and solder some lugs onto it.
For upgrading wiring that is contained in your wiring harness, just peel back the harness wrapping as far as you need, then splice in some new wire of the correct gauge and insulation type. It would be best to solder a 'lap' joint and cover with heat shirnkable tubing, rather than to use crimped connectors, as that wiring carries some decent amperage. Also, there is at least one fusible link in that starter bundle. If that is in poor shape you absolutely need to replace that whole link with a replacement link of the same size and quality. [The fusible link is just wire of a smaller size BUT, it has non-flammable insulation and terminal ends so that when it 'fries', it can't catch fire. Regular wire will not have those capabilities!!!]
use a Propane torch and solder them on.
an alternate method, use and electric stove, put the crimp and wire on the heating element and fire it up. Fill it with solder, turn off Burner, and let it cool down.
Be careful !
