Q Jet
Old Jul 25, 2011 | 12:01 PM
JackDidley's Avatar
JackDidley
Default Q Jet
I have an 80 with an earlier Quadrajet, bought used. I rebuilt it 4 years ago and it starts and runs good. Choke works well. It just idles rich, always has. Car has been parked a long time and I'd like to get it on the road. I'd apreciate any ideas to correct this.
Old Jul 25, 2011 | 12:22 PM
7T1vette's Avatar
7T1vette
First of all, you will need to know if that carb is a Rochester-built carb, a Carter-built carb, or an Edelbrock remake of that carb (after they bought the Q-Jet tooling). Yes, Carter did build some Q-Jets at a time when Rochester didn't have the capacity to supply all that GM needed.
You need to find the carb part number (in the case of the GM supplier-built carbs) or know which Edelbrock part that carb is (#1901, 1902, 1903, 1904, or 1906). For GM factory carbs, NAPA or other car parts store can order a rebuild kit (per the stamped part number) that will work for your unit. For Edelbrock carbs, you will need to order a rebuild kit from them for the model you have. You can order a kit that would be correct for the carb that came on your car originally, but it may not be correct for the carb you now have. If there is merely a difference in gaskets, etc. it can cause you problems.
I presently have a similar problem and my unit is an Edelbrock 1901 carb. I am waiting the shipment of two carb repair and modification books (ie, Ruggles; Roe). I'll likely end up buying the Edelbrock rebuild kit and then go through the carb per the 'expert' books' instructions.
Old Jul 25, 2011 | 12:39 PM
JackDidley's Avatar
JackDidley
Thanks, its a Rochester , I think maybe a late 70s truck application. I put a kit in it 4 years ago. Just thinking its a mechanical type problem. Like maybe the metering rods not seating. I remember having a hard time getting the linkage and all the top part stuff situated to get the top mated to the bottom.
Old Jul 25, 2011 | 03:15 PM
Rich's'78's Avatar
Rich's'78
If it has a 170xxxx number on the side it is a '75 or later model Roch. QJ. Car primary needles are no longer available and don't buy Edelbrock because they sell the fatter-tip truck needles (which may in fact be okay for you if it is in fact a truck carb, but check tip diamater first).
Believe it or not the primary jetting and APT setting affect idle mixtre, as of course does the float height and any air leaks (gaskets, hoses).
If you can't lean out the idle mixture by turning the screws clockwise, and the car gats decent mileage during cruise, I would try adjusting the APT first. Roe's book does a good job of explaining how.
I set mine (after engine mods) by turning it in (closkwise, down) until I got slight surging on cruise - it is very sensitive. Quarter to half turn counterclockwise and it runs great. Full travel for the APT stop screw is just over 8 turns out and mine runs and idles great at 3.5 turns out. Others need up to 5 out, depends on your manifold vacuum too. My idle vac is 16 - 17 inches.
Old Jul 25, 2011 | 03:36 PM
JackDidley's Avatar
JackDidley
I will look at the numbers. Later this week when I have time I think I will take a look at the needle and seat and float setting. Metering rods too. It would be easy to replace the carb but I like the way the car runs with this and dont want to throw $$$ at it just because I overlooked something thats fixable.
Old Jul 25, 2011 | 03:44 PM
Ganey's Avatar
Ganey
That could be it. Doug Roe book, Rochester Carbs (mainly about Q-J perf.) could help you.
Old Jul 25, 2011 | 04:41 PM
7T1vette's Avatar
7T1vette
I'm afraid that I don't remember the details, but I do remember Lars [Grimsrud] (the Q-Jet guru who was 'dismissed' from this Forum for unknown reasons) discussing that the truck Q-Jets were different from the car models. It also comes to mind that he had some reservations about using the truck models on a Corvette; but I don't remember why.
If you send him an e-mail requesting his advice on your situation, I feel that he would respond and give you the "straight skinny" on what to do. You will need to include any numbers stamped into the body of your carb, the model year of your car, type of transmission, and a summary of any modifications that you have made to the engine.
V8FastCars@msn.com
Old Jul 25, 2011 | 09:28 PM
JackDidley's Avatar
JackDidley
V8FastCars@msn.com
I wondered about Lars, had not seen him post in a while. I'd bet I can find him on anoyher furum. May play with it tomorrow.
Old Jul 25, 2011 | 10:58 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Will the engine die if the idle-mix screws are screwed all the way in?
Old Jul 25, 2011 | 11:18 PM
JackDidley's Avatar
JackDidley
Did not try that yet. I think it may just be the float setting or the needle valve. Was looking down in the primary side and saw some fuel flow after I shut the the motor off. Then it ran out of gas. Had to put my mower gas in it just so I could park it. Going to get plates on it this week so I can get to the gas station and get out for a test drive.
Old Jul 25, 2011 | 11:40 PM
rcread's Avatar
rcread
I would call Cliff and get a rebuild kit designed specifically for your application. He wrote the book. I have a carb he built for my '72 LeMans and it's perfect.
Old Jul 26, 2011 | 07:30 AM
qtlow's Avatar
qtlow
You can check to see if the power piston and metering rods are moving freely by sticking a small screwdriver down the fuel bowl vent tube and operating the piston up and down. The screwdriver must be in the forward most side of the tube though.
Old Jul 26, 2011 | 08:33 AM
JackDidley's Avatar
JackDidley
Didnt know that. Now I have a few things to try. I will get on it in the next couple days. It was running nice last night, till it ran out of gas. I think its going to be fixable.
Old Jul 26, 2011 | 01:58 PM
Rich's'78's Avatar
Rich's'78
I never understood what Lars had against the truck QJs. I have used 2 different 1985 models on different cars, including my Vette, with excellent results. The primary venturies are a bit different, but they work great when set up right. Stick to 1975 model to 1980 models. The Canadian '85s had no electronic controls, unlike the US '81 models. Ours were like the 1980 US models.
Old Jul 26, 2011 | 04:55 PM
73, Dark Blue 454
Given a choice, a 1974 or earlier (pre-smog) q-jet is better for performance. They have a wider range of adjustment.
Here's really good q-jet white paper from a couple of guys who know their stuff. They're both tough as nails on the track,..SE class, usually Ponchos. The mods they suggest will work great on the street.
http://home.comcast.net/~gtopercy/Pi...rajetTech.html
Good luck!
Old Jul 26, 2011 | 09:45 PM
JackDidley's Avatar
JackDidley
Good luck!
Thanks. Great article. Best Ive seen regarding the jets/metering rods. The next 2 days, I should have time to work on it. Bad news is, its going to be 97° here.
To Q Jet
