mallory unilight
Old Apr 26, 2002 | 08:42 PM
danzig74c's Avatar
danzig74c
Default mallory unilite
i bought the mallory unilite kit
and a new coil
i'm gonna put it on this weekend
has anny one have anny experiance whit it
the + and - of the system
i heard it whas better than the one from petronix
[Modified by danzig74c, 6:42 PM 4/26/2002]
Old Apr 26, 2002 | 10:00 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Default Re: mallory unilite (danzig74c)
I ran the Unilite conversion in my stock distributor for years, never skipped a beat :cheers:
Old Apr 26, 2002 | 10:01 PM
corvgreg's Avatar
corvgreg
Emerging Vendor
I had the Unilite conversion on my 71 for 6 years, and never gave me a problem. If I remember, the voltage to the distributor has to be below a certain level or it can harm the sensor. Make sure you check this. I added a MSD 6AL to add more punch and a rev limiter(which came in handy at the dragstrip).
Old Apr 26, 2002 | 11:07 PM
1Bad69's Avatar
1Bad69
Default Re: mallory unilite (corvgreg)
i just had the petronix put in...so far so good....i called summit racing and they recommended i stay with an accel conversion(my dist.is an accel dual points)..the local speed shop here says they have not had any complaints about the petronix...crossing my fingers... :cheers:
Old Apr 26, 2002 | 11:11 PM
ddecart's Avatar
ddecart
SPARTAN
CI 3-4-5-6-8-9-10 Vet
CI-9 AutoX Winner
CI-3 Go Kart Champ
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
I've had one for 3 (4?) years now. Been nothing but trouble free. AND NO POINTS!!!
It does require a voltage of 6 volts, not 12. So you may need a ballast resistor to drop the voltage to the coil.
Old Apr 27, 2002 | 12:09 AM
MYPET70's Avatar
MYPET70
:yesnod: :yesnod: :yesnod: :smash: :cool: Oh yes, this is a GREAT setup and you'll love it. I ran one in my stock distributor for over 7 years and would have kept on using it until the tach drive gave out...then I put in entirely new Unilite Distributor... NEVER, NEVER even the slightest problem! For my '70 I found it best to remove the distributor for installation ease and you need to pay very close attention to the directions...especially the part about the ballast resistor if you need one. Also make sure to use the grease they supply that goes between the unit and the base of the distributor. ENJOY!!!!
Old Apr 27, 2002 | 12:28 AM
RatRacer's Avatar
RatRacer
Default Re: mallory unilite (gsk@sprintmail.com)
Another pleased Unilite user here. I've had one on the car below for eight years. I also installed a Mallory HyFire ignition box at the same time. Good stuff.
[Modified by RatRacer, 10:28 PM 4/26/2002]
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Default Re: mallory unilite (1bad69)
1bad69, is your dual point the 3400 series? I've been considering the pertronix conversion for mine but have heard all the horror stories :(
Old Apr 27, 2002 | 07:47 AM
danzig74c's Avatar
danzig74c
Default unilite
Super! :D
Old Apr 27, 2002 | 10:25 AM
1Bad69's Avatar
1Bad69
Default Re: mallory unilite (yellow 72)
It is the Racing2 Dual Points 34000A i believe...
Old Apr 27, 2002 | 10:35 AM
Go-Gone's Avatar
Go-Gone
I have run one in the vette for years now with no trouble. I also have one in the 65 Mustang also with no problem. Just one word of caution, dont ever try and crank the engine or "bump" it with the starter with the ground wire disconnected. Poof goes the module, dont ask how I know.
Old Apr 27, 2002 | 01:59 PM
WESCH's Avatar
WESCH
Hi
What's the cost of this unilite conversion kit, if I may ask ?
Where did you get it from ?
Did the resistor come with it ?
Thanks Gunther :seeya
Old Apr 27, 2002 | 03:17 PM
danzig74c's Avatar
danzig74c
Default Re: mallory unilite (WESCH)
i bought it by jeg's
http://www.jegs.com/cgi-bin/ncommerc...053&prmenbr=76
:D
To mallory unilight
