Distributor alignment
Old Jul 28, 2011 | 12:58 AM
alyle5864's Avatar
alyle5864
Banned Scam/Spammer
Default Distributor alignment
How do you properly align the distributor so that it is square with the engine? What I am trying to do is line up the dist so that the plug wires are purpendicular to the engine.
Old Jul 28, 2011 | 08:51 AM
Timsride's Avatar
Timsride
Im not sure that I am following totally what you are asking but Im assuming you want to change the position where the #1 and so on are positioned on dist. Do a search for clocking dist. and you will find good info how to move firing order forward or backward from position its at.
Old Jul 28, 2011 | 12:57 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Stock distributors and intake manifolds have factory stake marks for alignment purposes. AIM shows how to do it since distributors were installed on the engine dress line.
Bring #1 to TDC on the compression stroke. Lower distributor and align the stake marks. Set the timing.
AIM also shows correct spark wire routing, but I can't say whether that will meet your definition of "perpendicular."
Old Jul 28, 2011 | 01:36 PM
...Roger...'s Avatar
...Roger...
Which direction and how far do you need to go , a pic would be nice ?
Old Jul 28, 2011 | 01:40 PM
Mike Ward's Avatar
Mike Ward
Not to start another fight, but it really helps when people mention the year and egine type of their car and whether it's stock or not.
Pre-'75 Corvette dizzys are not aligned with the motor or have perpendicular anythings...............
Old Jul 28, 2011 | 03:09 PM
pawpaws toy's Avatar
pawpaws toy
[QUOTE=alyle5864;1578252388]How do you properly align the distributor so that it is square with the engine? What I am trying to do is line up the dist so that the plug wires are purpendicular to the engine.[/QUOTE Assuming you have a HEI dist., move the #1 plug wire to the #8 pos. and so on until #2 is where #1 started. (Moving all wires clockwise 1 post) Now retime the engine and the dist sides should be close to square with the firewall & engine.
Old Jul 28, 2011 | 05:19 PM
billla's Avatar
billla
St. Jude Donor '14
I'm thinking the OP saw one of those nice caps that neatly routes the wires out either side of the distributor.
If so, this is about buying a cap that has those types connections - not about clocking the distributor. Something like this one:
If I'm off-base, then a little more clarity would be good
Old Jul 28, 2011 | 08:10 PM
noonie's Avatar
noonie
For what it's worth to you, here is the proper position of the hei.
#1 wire is the closest and furthest left.
These are the factory stake marks.
The main purpose to position both the hei and the points dist was to allow timing room for the vacuum advance can.
Old Jul 28, 2011 | 08:54 PM
Chuck72's Avatar
Chuck72
Great post, noonie!
I guess that is the answer the op was seeking.
The photo really finishes it.
Chuck
Old Jul 28, 2011 | 09:56 PM
...Roger...
The way I read the OPs post is that he has the dist in,and timed,but the dist is not sitting square like Noonies pic and he wants to know how to get it in that position without getting it out of time.
Could be wrong but I was waiting for him to confirm thats what he wants,and also to confirm how far off the dist is from square.
Old Jul 29, 2011 | 01:07 AM
alyle5864's Avatar
alyle5864
Banned Scam/Spammer
This is what it looks like. I was hoping to be able to set the dist. so that the plug wires were symmetrical. As you can see the dist is rotated ccw slightly not allowing this.
BEFORE anyone says, that's a corrected GM cap, the wires are correct.
Old Jul 29, 2011 | 05:13 AM
noonie's Avatar
noonie
R&r dist shaft clockwise 1 tooth.
Old Jul 29, 2011 | 09:42 AM
...Roger...
Hmmm , Interesting cap , I've heard of them but never looked inside to see how they are constructed. My choice using the factory cap would be to do as Noonie says and lift the dist and rotate 1 tooth clockwise to keep the wires in the correct location in the cap.
Noonie,with this type of cap could he just move the plug wires around 1 spot or do they have to stay in their present locations ?
EDIT - To alyle5864 , that would be a big NO on moving just the wires.
Old Jul 29, 2011 | 10:03 AM
billla's Avatar
billla
St. Jude Donor '14
The picture I posted was HEI, but the cap I was thinking about was for non HEI where it's a bit more of a rat's nest.
Since it's HEI, noonie's approach is right on - moving the distributor 1 tooth at a time until the wires are where they're wanted and the timing is right. Can't just move the wires, as that would change the timing...
Old Jul 29, 2011 | 10:10 AM
pawpaws toy
What kind of cap do you have? Is there a type of internal wiring to have the firing order come out the way it does? It really looks good.
Old Jul 29, 2011 | 10:16 AM
...Roger...
Billa
That's what I thought after looking at the pic of the cap a little more but I still can't wrap my brain around how the cap is made.
Inside the cap at the rotor it has to be 1-8-4-3-6-5-7-2 and then outside its 1-3-5-7-2-4-6-8 ??? I need a drink.
Old Jul 29, 2011 | 10:20 AM
pawpaws toy
Originally Posted by ...Roger...
Billa
I know what you mean. I even checked online to see if anyone made a SBC cam with a different firing order.
To Distributor alignment
Old Jul 29, 2011 | 10:47 AM
pawpaws toy
http://www.yearwood.com/index.cfm/pa...286/prd286.htm
Old Jul 29, 2011 | 11:23 AM
noonie's Avatar
noonie
These caps were made by Accel and available in 4 or 5 colors.
Somewhere I had a pic of a transparent demo cap. They are made with brass traces like little bussbars molded in the plastic to reroute the terminals. Initially they had some problems with crossfire, don't know if that was corrected or not, I assume so.
There were also a bunch of different firing order cams, but really nothing to do with a cap.
The correct way to set the dist is with the gears, not only for the vac can,but also for premade wires to fit for length.
Old Jul 29, 2011 | 11:30 AM
Mike Ward's Avatar
Mike Ward
Putting the 'magic cap' aside, as others have said the correct way of orienting the distributor body to the engine is to remove the cap and mark the relative position of the rotor to the body. Remove the distributor, turn the oil pump shaft clockwise by the desired amount then drop the dizzy back taking into account the helical drive gear.
The rotor and body must end up in the same relative position as when you started. Set final timing using a light and secure the distributor.
