Headlight Problem
Old Jul 31, 2011 | 10:06 PM
art72's Avatar
art72
6th Gear
Default Headlight Problem
I recently purchased a 72. When I shut the car off, my left headlight pops up. I haven't had a chance to look at it yet, but any hints would be appreciated. Thanks
Old Jul 31, 2011 | 10:44 PM
scottyp99's Avatar
scottyp99
Here's a link to a thread that will tell you pretty much everything you need to know about the vacuum system that controls your headlights.
http://forums.corvetteforum.com/c3-t...tem-works.html
Scott
Old Aug 1, 2011 | 09:05 AM
78IndyPace's Avatar
78IndyPace
Since it is only the left one, I suspect a vacuum leak in the top of your relay for that headlight. Could be the diaphragm inside the metal "hat" or the small, white-striped hose connected to it. If the diaphragm is leaking, there is no repair I know of and the relay must be replaced.
Old Aug 1, 2011 | 09:18 AM
...Roger...'s Avatar
...Roger...
A quick test for this is:
with engine running , pinch the small hose going to the metal hat of the left relay,wait for 15 seconds,if the HL pops up you have a leak in the hat or the little white striped hose between your pliers and the hat.
Old Aug 1, 2011 | 07:39 PM
art72's Avatar
art72
6th Gear
Thanks for the help, the information from that link is great!!!
To Headlight Problem
