Header Bar Installation File Now Available
Old Aug 1, 2011 | 09:24 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Default Header Bar Installation File Now Available
I've uploaded the headlamp header bar installation help file on our web site.
I thought I would start a thread so if anyone had questions. There are s few typo's in there that will be corrected tomorrow but that will be the easy part.
Willcox
Corvette Headlamp Header Bar Installation 1968-1982 Click on Supporting Document!
http://willcoxcorvette.com/repairand...lp.php?hID=322
Old Aug 1, 2011 | 09:27 PM
1Fordman's Avatar
1Fordman
Ernie,
Clicking on the link brings up engine block casting number information.
Old Aug 1, 2011 | 09:30 PM
0Willcox Corvette
Former Vendor
Fixed.. sorry about that.. previous post copy link stuck in there..
Old Aug 1, 2011 | 09:47 PM
'75's Avatar
'75
That's a great write up, you make it look a lot easier than I imagined it.
Old Aug 1, 2011 | 09:54 PM
0Willcox Corvette
Former Vendor
By leaving the old bonding strip in the header it affords you the luxury pf not being so soft with it. Cutting the old bonding strip away from the upper surround panel can be tedious work and often result in cracks in the corners. The upper surround panel is pretty flimsy without the header or bonding strip.
The update will be worked tomorrow.
Old Aug 2, 2011 | 09:48 AM
0Willcox Corvette
Former Vendor
Ok, I think the file is fixed and ready to fly! In my opinion the only correct way to do this repair is from the bottom and not the top.
Old Aug 2, 2011 | 11:58 PM
0Willcox Corvette
Former Vendor
bump
Old Aug 3, 2011 | 11:36 PM
0Willcox Corvette
Former Vendor
bump
Old Sep 14, 2011 | 07:56 PM
0Willcox Corvette
Former Vendor
bump
Old Sep 14, 2011 | 11:11 PM
Ghunt's Avatar
Ghunt
Am I reading this wright and the rivits dont go through the fiberglass?
What is it that the rivits attach to and if the rivits dont go through the fiberglass and by clmping down the dimples can you avoid repainting.
(if everything goes as planned)
Thanks for a great DIY report
George
I believe I answered most of all my questions by re reading and carefully looking at the pictures
several times.
That brings up another question, is the old header glued to the bonding strip an then rivited before
installing at the factory?
Old Sep 15, 2011 | 12:22 AM
0Willcox Corvette
Former Vendor
On the original design, the bonding strip was riveted to the header and then bonded in place. When we remove the header we leave the original bonding strip on the upper surround panel.. we just remove all traces of the rivet so that there are no issues down the road.
To Header Bar Installation File Now Available
