Propane??
Old Aug 2, 2011 | 06:20 PM
laytonkopplin's Avatar
laytonkopplin
Default Propane??
I was thinking about changing my corvette over to PROPANE.
Has anyone done this I remember my father telling me when I was a boy that he use to have a truck that ran on PROPANE and he was making great MPG on the highway and in town. SO what I'm getting at is has anyone done this to there corvettes and maintained the same horse power and toque and was able to travel long distance's??
Old Aug 2, 2011 | 06:35 PM
beernut's Avatar
beernut
Quite a few people do it over here (Norway) with big trucks and such, but I have never heard of anyone doing it with a Vette...
Converting a gasoline burner to run on CNG/LNG is ... well ... not straight forward unless you can find a conversion kit you can use.
Googling for "CNG conversion Corvette" will bring up some more or less interesting stuff - also some posts from these forums.
Might also want to shoot an e-mail to these guys (or a local dealer) to see if they can offer any help or insight: http://www.parkwaychevrolet.com/part...cng-conversion
Old Aug 2, 2011 | 06:38 PM
'75's Avatar
'75
I have heard, not sure if it's true or not, that converting to propane will cost around 25% of your power.
Old Aug 2, 2011 | 06:45 PM
laytonkopplin
well its a thought that could be something to look at
Old Aug 2, 2011 | 07:29 PM
Duane4238's Avatar
Duane4238
Where would you put your propane tank? Certainly not in the passenger or engine compartment!!!! I think it might look a little tacky mounted on the outside behind the rear window. Someone might mistake you for a fancy tow motor or forklift.
Duane
Old Aug 2, 2011 | 07:49 PM
PeteZO6's Avatar
PeteZO6
This site gives some information about propane including that has about 86% of the energy as gasoline. It therefore requires more storage volume to drive an equalivant distance as gasoline. My '69 Corvette has a 20 gallon tank, pretty squared off top to bottom and front to back. You'd have to find a cylindrical tank that you could get into the fuel tank space in the car which I think would give you even less volume. Filling up every hundred miles or so would be a major PITA, especially considering propane filling stations aren't on every street corner.
LINK
Good idea perhaps on a truck, but I think the downside on a Corvette makes it impractical. Give it your best shot.
Old Aug 2, 2011 | 09:03 PM
7T1vette's Avatar
7T1vette
Hey, at least you could put a fitting on the rear panel to hook up your gas grill when you go to a picnic.
Old Aug 2, 2011 | 09:49 PM
laytonkopplin
now there's a idea!
Old Aug 2, 2011 | 10:02 PM
Mike Ward's Avatar
Mike Ward
Or if there's a leak somewhere, the car could serve as the grill.
Running on propane will reduce fuel costs by only around 30%. It will take decades to offset the conversion costs.
Old Aug 2, 2011 | 10:18 PM
laytonkopplin
I googled the cost and to get everything you need cost around 131.00 for the larger V8's
Old Aug 3, 2011 | 11:36 AM
7T1vette's Avatar
7T1vette
Conversion amounts to swapping the fuel tank for some pressure tanks, installing a regulator and electrically operated shut off valve, and modifying the carburetor. Probably more than $131, but it wouldn't have to be expensive.
Hey, when you get done, the weight distribution on the car will be better! And your car can smell like a fork truck...
Old Aug 3, 2011 | 03:04 PM
noonie's Avatar
noonie
My 1ton was propane for a number of years and for my use it was a PITA. In Florida you must buy a road tax sticker to allow legal fillups.
Lots of advantages for high mileage/usage engines. After 5000 miles oil still looks brand new, engines last 2 or 3 times longer, much cleaner emissions etc.
County fleets here have lpg or cng on their vehicles.
Almost all the conversions are dual fuel, so space can be a problem.
Sold my setup on eBay less tank for 150 bucks.
Still use propane on forklift.
Old Aug 3, 2011 | 03:09 PM
Vette5.5's Avatar
Vette5.5
I recall a couple articles years ago on guys with really high hp car drive line build up's in California, converting to LP to pass the emissions sniffer tests. Wont work today though, as also includes a visual inpection, to make sure all the stock emissions equipment is there.
Old Aug 3, 2011 | 03:20 PM
laytonkopplin
ya I use to drive a fork lift that ran on propane
Old Aug 3, 2011 | 11:24 PM
68/70Vette's Avatar
68/70Vette
Propane also works really good as an airconditioning refrigerant. I remember seeing a picture of a Porche pretty much burnt down to the ground where the propane refrigerant leaked and caught fire.
Old Aug 4, 2011 | 02:49 AM
tfi racing's Avatar
tfi racing
Crap!I just wasted $20 refilling the spare tank for the grill ,if I known I could convert one of my vehicles for only another $111 more,I could have enjoyed the best of both worlds...
Old Aug 4, 2011 | 07:18 AM
Garys 68's Avatar
Garys 68
Advantage, propane is around 110 octane, so you can run high compression. It has a little less energy (btu) compared to gas.
It may be even cheaper than you think. There's a tax credit or deduction up to $4000 to offset conversion costs.
To Propane??
