Exhaust Heat Valve
Old Aug 2, 2011 | 07:58 PM
toms78vette's Avatar
toms78vette
Navigator
Default Exhaust Heat Valve
Do I need the Exhaust heat valve when I change out stock exhaust and put headers and dual exhaust on
Old Aug 2, 2011 | 08:08 PM
81pilot's Avatar
81pilot
NOPE....Next.......
Old Aug 2, 2011 | 08:19 PM
scottyp99's Avatar
scottyp99
Getting rid of that valve is just one of the many reasons for upgrading exhaust!
Scott
Old Aug 2, 2011 | 08:22 PM
LancePearson's Avatar
LancePearson
My 76 now true duals has no heat valve, no A.I.R. pump, etc. The heat valve was supposedly I read once put there to put some heat back into the intake to preheat the air to produce less pollutants until the engine was hot then the spring opened it back up.
I'd think it was just another piece of crap to coke the power out of the engine and is well rid of if the above explanation is accurate. Either way, my 76 L48 runs just fine without it!
Old Aug 2, 2011 | 08:58 PM
7T1vette's Avatar
7T1vette
The heat riser valve is there to help heat the carb/choke in cold weather, so that the engine will warm and drop the choke sooner. It had nothing to do with emissions. If you won't be using the car in really cold weather, there is no need to keep it. You can then put block-off plates in the heat riser channel on the intake. That will reduce unnecessary heating of the carb.
Old Aug 2, 2011 | 09:15 PM
jb78L-82's Avatar
jb78L-82
You don't need it. Get rid of it!
Old Aug 2, 2011 | 11:04 PM
Mick71's Avatar
Mick71
St. Jude Donor '13-'14-'15,'21
Would these be part of special intake gaskets?
Old Aug 3, 2011 | 11:32 AM
7T1vette's Avatar
7T1vette
Almost all of the intake gasket 'kits' have the little aluminum block-off plates in them.
Old Aug 3, 2011 | 11:36 AM
LancePearson
Default epa
I thought that they did everything from 195 degree thermostat to heat risers to heat the air more from beginning to end so there would be less specific pollutants so heating the engine which in turn activates the choke tends to support that in an engineering sense.
At least from the reading I've done so I'd want to expand the context of what you said above as it all had to do with combustion and in that generation emissions.
Lance P.
Mike Ward's Avatar
Mike Ward
I once removed the valve from a year round beater I had back when I believed that everything GM did was evil and robbed power. All I got for my trouble was a car that wouldn't idle worth a da*m for the first twenty minutes or so during the winter.
Old Aug 3, 2011 | 02:39 PM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I wired mine open because I don't drive in cold weather and it was burning up the paint on the intake manifold.
Old Aug 3, 2011 | 04:28 PM
7T1vette's Avatar
7T1vette
Heat risers have been on cars for much longer than the EPA has been in existence. They may have an effect on reducing emissions (compared to the same car but with no heat riser), but that is coincidental. Of course, the manufacturer would put some 'spin' on it to impress the Feds that they were "working hard to reduce emissions"...
Old Aug 3, 2011 | 04:58 PM
Rich's'78's Avatar
Rich's'78
The heat riser valve (called Early Fuel Evaporization valve by GM) is there to do just that. Gasoline needs heat to vapourize it so it will burn. Liquids don't burn - their vapour must mix with oxygen in the air to burn. When the engine is 'cold', the gasoline is still partially liquid and doesn't burn as well (a pseudo-lean condition) as when it gets heat from the hot intake manifold. So, the choke mixture has to be richer and stay active longer than without it.
Usually, when you change the exhaust system (and remove the EFE) you adjust the choke slightly w/o knowing you are partly compensating for that.
Here we go again ..... Years ago GM did a series of tests and found a 1/2" hole in an otherwise completely blocked intake crossover system made the mixture burn better than a completely blocked intake crossover system. That was with a carb though, not MPFI. AT WOT it is inconsequential.
Old Aug 4, 2011 | 10:08 PM
gcusmano74's Avatar
gcusmano74
If you live in Wisconsin or some other cold climate, you will not be happy with how the engine runs on startup for the first 5 or 10 minutes in November, December, January, February or March...
I tried adding some weight to the iron counter weight on my heat riser so it would open sooner and stay open longer. I drilled and tapped the counterweight, and added a stud and some heavy nuts on the end. Looked ugly, but it worked fine.
Old Aug 4, 2011 | 10:52 PM
81pilot's Avatar
81pilot
I drove my car a lot last winter even when we were at 0-20 degrees and it started and warmed up fine even without the riser,and with headers and I don't wait to go to work. I think a little choke adjustment and if it is tuned right the adjustment will more than compensate for it. JM2C
To Exhaust Heat Valve
