Has anyone had any problems with the 82 crossfire injection that either couldn't be fixed or were extremely expensive to repair?
I'm the second owner and I can say nothing related to the induction system has ever failed. ( I hope I didn't jinx myself) 101,000 miles and still running strong.
CFI parts are all relativly cheap, most are available at bargain prices on Ebay. Only problematic things are the air switch & diverter valves but you can use the 84 ones (not factory correct).
The engine is relativly easy to maintain and problems are easy to fix. A lot of info can be found here: http://www.crossfire.webhop.net
or https://www.crossfire.homeip.net if the above link doesn't work for you (this is a secure connection so it's slower!)
