A/C and marbles
Old Aug 5, 2011 | 07:36 PM
Wrecked82's Avatar
Wrecked82
Default A/C and marbles
A/C sounds like it has a bunch of small marbles inside it. Does this mean I need a R12 recharge? New compressor about 2 years or less ago.
Old Aug 5, 2011 | 11:14 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Larry-
I'm not sure what you mean by marbles, but whatever it is it sure doesn't sound good.
Low Freon won't sound like marbles, so I'd have to go with a bearing in the compressor as a guess.
If you can, turn on the ac and put a stick on the compressor. I know this sounds Bubba but it works. You'll hear the noise on the stick and know for sure.
Willcox
Old Aug 6, 2011 | 01:01 AM
noonie's Avatar
noonie
Either there is way too much refrigerant in it, blockage on the high side or it's just wearing out.
My wife's newer Caravan has been like that at idle for a couple of years. Sounds terrible, but cools better than 99% of vehicles out there. I'll fix it when it gives up.
Old Aug 6, 2011 | 07:50 AM
rugerm44's Avatar
rugerm44
Only problem with that is when takes a crap it dumps all kinds of fun peices in the system.If you don't get them cleaned out well they eat up your new compressor.
Old Aug 6, 2011 | 09:34 AM
noonie's Avatar
noonie
All compressor replacements require complete flushing anyway.
Old Aug 7, 2011 | 10:06 AM
0Willcox Corvette
Former Vendor
Most people don't realize that its just not as simple as replacing the compressor. Noonie is right too, it could be freezing up from over-charge.
Old Aug 7, 2011 | 10:26 AM
L88Plus's Avatar
L88Plus
That doesn't always work...a lot of crap gets stuck in the evap and condensor coils that will break loose over time and mess up the next one.
Old Aug 7, 2011 | 10:31 AM
mikep3's Avatar
mikep3
JMOP,
If the belt is loose on mine it sounds like marbles because the belt is hitting a guard on the lower support rod. From there a loose belt causes the AC compressor to slip and chirp loudly.
You may want to check the belt and the belt tension, which needs to be very tight.
When mine AC is low on 134A it short cycles or will not start because of low pressure switch.
Old Aug 7, 2011 | 12:21 PM
Manuel Azevedo's Avatar
Manuel Azevedo
Can you identify where this noise comes from, compressor, in the dash and such? Does it seem like maybe it is the fan? Junk can get into the fan housing and get beat up by the squirrel cage fan making a sound something like you suggest. If it is a fan issue it would also do it with the heat also. Try just turning the fan on without the air to eliminate that as I problem.
Old Aug 7, 2011 | 07:19 PM
Wrecked82's Avatar
Wrecked82
Have had a problem with the fan wanting to hit the fan shroud, but fixed that. It is the compressor overall. When compressor not on or not engaged, no rattling sound. Maybe it is the clutch. Is the clutch internal or external?
Old Aug 7, 2011 | 07:38 PM
Ganey's Avatar
Ganey
Note above post. By new if you mean rebuilt, R4s are sometimes noisy or can become noisy & work for a long time. A/C guys say it takes very special equip. "a wonder to behold" to do R4s.
Old Aug 8, 2011 | 11:02 AM
Wrecked82's Avatar
Wrecked82
No, it was a brand new AC Delco R4. Shop that installed it is a very high quality shop in Sugarland. Does nothing but professional work. Going to check with them today.
Old Aug 8, 2011 | 12:22 PM
TopGunn's Avatar
TopGunn
Or could it be the mice have brought in some acorns and they're rattling around in the airbox! The little ba$tards do that to my daily driver all the time until I kill them!
Old Aug 8, 2011 | 01:29 PM
Wrecked82's Avatar
Wrecked82
Took it in already. Full of freon. No problem with clutch. Throughly inspected. Nothing wrong according to shop. Just when it is so hot outside and when sitting at light, etc., pressure can build up. They claim the R4's can make rattling sound. It is a new compressor and shop, again, it a very, very good shop. Great reputation. So, now to chase down those squirrels!
To A/C and marbles
