Hey where's that fuel pump install thread ?
Old Aug 6, 2011 | 11:03 AM
boltnut's Avatar
boltnut
Default Hey where's that fuel pump install thread ?
I thought I saw reference to a thread with some trick for a pain free fuel pump swap......?
Old Aug 6, 2011 | 11:13 AM
Ganey's Avatar
Ganey
The first time I did a fuel pump on a Corvette w/ A/C, looked the situation over & pulled the right front tire & used long extensions. Have posted that tip many times. Esp. for A/C.
Old Aug 6, 2011 | 02:20 PM
boltnut's Avatar
boltnut
wasnt there something about that pushrod ? or dont i have a pushrod in a 73 ?
Old Aug 6, 2011 | 02:32 PM
centralcalvette's Avatar
centralcalvette
There is a pushrod that operates the pump. There is a short bolt (9/16 head, 3/8 threads) that plugs the special hole. The bolt comes in from the ront of the engine, in front of the pump. Remove the bolt, carefully put a longer(perhaps 1.25") bolt snugly in the hole, replace the pump, and reinstall the original "plug".
Old Aug 6, 2011 | 02:34 PM
boltnut's Avatar
boltnut
aha ! cant wait to find the special hole !
Old Aug 6, 2011 | 02:55 PM
Paul L's Avatar
Paul L
Roger shows it very well here.
http://forums.corvetteforum.com/c3-t...p-r-and-r.html
Old Aug 6, 2011 | 03:47 PM
boltnut's Avatar
boltnut
Originally Posted by paul 74
thanks but i went out to do it before i read that. it appears my pushrod had already dropped. maybe i went too slack on the "plug" bolt. i guess ill take it out and inspect and push back in....hope to get pump on fast enuf so it wont fall back down...
Old Aug 6, 2011 | 04:03 PM
Paul L's Avatar
Paul L
It won't move if you use the grease technique.
Old Aug 6, 2011 | 04:11 PM
shrekviper's Avatar
shrekviper
GREASE!!! Just did mine, works perfect...
Old Aug 6, 2011 | 05:40 PM
boltnut's Avatar
boltnut
ok. gonna grab some in the AM.....thanks guys.
To Hey where's that fuel pump install thread ?
