MYSTERY MARKINGS FOUND???????
Old Apr 28, 2002 | 03:05 PM
Mr.Gearhead's Avatar
Mr.Gearhead
Default MYSTERY MARKINGS FOUND???????
Hi all,
After taking down the gas tank I found some white chalk markings. They are on the fiberglass panel that makes up the interior back wall where the convertible folds down. See picture.... what does 248 mean?????
http://temp.corvetteforum.net/c3/bendera/page2.shtml
Old Apr 28, 2002 | 03:14 PM
78Vette-SA's Avatar
78Vette-SA
Default Re: MYSTERY MARKINGS FOUND??????? (Mr.Gearhead)
It's not an option code in the Black Book but perhaps part of your VIN so they know what body went with what frame? Or maybe the Job Number which tied to the build sheet?
Old Apr 28, 2002 | 03:21 PM
Mr.Gearhead
Default Re: MYSTERY MARKINGS FOUND??????? (78Vette-SA)
I looked everywhere.... books, online..... SOMEONE HAS TO KNOW WHAT THIS is FOR! It does not match my VIN. It is like a piece of history.... someone in 1970 put this on the car for a reason... I was just curious why??? :confused: :confused: :confused:
Old Apr 28, 2002 | 03:29 PM
LATNC3's Avatar
LATNC3
maybe its is a salvage part put on by previous owners!!@@ :confused:
Rod :cool:
Old Apr 28, 2002 | 03:31 PM
PRNDL's Avatar
PRNDL
Default Re: MYSTERY MARKINGS FOUND??????? (Rod Rodriguez)
Is that what they call a "job number" ? Ask Juliet, she might have an idea. MJ
Old Apr 28, 2002 | 04:03 PM
Binnie77's Avatar
Binnie77
They are referred to as "sequence numbers" or "job numbers". You will see one on the floor of my car in this picture as well. The numbers along the frame refer to shim sizes for the body mounts.
Old Apr 28, 2002 | 05:32 PM
Mr.Gearhead
Default Re: MYSTERY MARKINGS FOUND??????? (Binnie77)
Binnie, is that a new firewall you have there? I can see rivets all around that area. Mine is cracked and I need to install one. Did you do this? How much is involved on the topside?
Thanks for the info on the markings!
Old Apr 28, 2002 | 05:55 PM
Larry B.'s Avatar
Larry B.
That is the job number. They seem to start over evry 500 cars in sync with the last three numbers of the V.I.N. .. ****239 or ***739 vin's would both have 239 job numbers but there have bee a few that are one number off for some reason.
Old Apr 28, 2002 | 06:08 PM
GaryS's Avatar
GaryS
Default Re: MYSTERY MARKINGS FOUND??????? (silvervetteman)
As others and Silvervetteman state, this is certainly the job number. The job number MAY correlate with the VIN, as they do on my 72, but there are numerous examples where they are close but not the same. I think Juliet's web page had some of the repsonses from folks who found the job number and correlates them to the VIN.
Gary
Old Apr 28, 2002 | 06:15 PM
454Big's Avatar
454Big
Default Re: MYSTERY MARKINGS FOUND??????? (GaryS)
Another idea might be the julian date?? Does this correspond in any way?
Old Apr 28, 2002 | 06:55 PM
GaryS's Avatar
GaryS
Default Re: MYSTERY MARKINGS FOUND??????? (454Big)
No, absolutely no bearing on the julian date.
The job number is well documented on various NCRS cars and is clearly just an assembly line item to match compenents. That is job number 421 USUALLY comes after job 420 and before 422. I have the job number under the head liners of both T tops, in the same position as the photo in question, on the right side of my transmission tunnel in the interior, and under the carpet in the rear of the car. I have these photos documented with a digital camera and since my job number is 421, the car was built November 3, and the fact that there ain't no 421st day, the job number has no bearing on the date.
Gary
Old Apr 28, 2002 | 07:00 PM
Steve's Avatar
Steve
I've seen more than on that does not seem to relate to the vin at all.
Mine is a good example
last 3 digits of the vin 868
and you can see the marking on the body 370
-Steve
[Modified by Steve, 5:02 PM 4/28/2002]
Old Apr 28, 2002 | 07:39 PM
Binnie77's Avatar
Binnie77
No, that is original, I just cleaned it up, the rivet heads were protected over the years with oil and grease.
Old Apr 28, 2002 | 07:40 PM
Larry B.'s Avatar
Larry B.
O.K. guy's.... My 69 has 129 all over the place, rear filler, behind the seats, and a few other places. My tank sticker has 129 written on it. My v.i.n. ends in 129 so I feel confident in Juliet's research data.
Old Apr 28, 2002 | 08:01 PM
Juliet's Avatar
Juliet
Some shuffling may have gone on at the factory between the job numbers and when the VINs got slapped on the bodies. The way some of the guys who worked at these plants explained the process to me I can't see how they would be absolutely correlated - however there does seem to be quite a bit of evidence that the numbers are loosely correlated with the VIN. The '70 Registry has a bunch of numbers / build sheets etc from various shark owners. If anyone has any new stuff they would like to add - please send me the information and I'll add it to the database. Just so you know, I'm hopelessly behind updating the registry so it's likely to be at least a month before I get it online (just so you don't think I'm ignoring you or don't appreciate the info.) :crazy:
Old Apr 28, 2002 | 08:02 PM
Juliet's Avatar
Juliet
Default Re: MYSTERY MARKINGS FOUND??????? (Juliet)
I forgot - here's the URL for the Registry job number data page:
http://corvetteforum.net/c3/1970registry/JobNo.html
Old Apr 28, 2002 | 11:29 PM
ddecart's Avatar
ddecart
SPARTAN
CI 3-4-5-6-8-9-10 Vet
CI-9 AutoX Winner
CI-3 Go Kart Champ
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
Default Re: MYSTERY MARKINGS FOUND??????? (Steve)
-Steve
Steve,
Your's doesn't look far off. If they start at 0 every 500 vehicles, yours is only off by 2.
500=001
501=002
etc...
868=368
so it's only off by 2. Things could easily have been rearranged at some point in the plant.
To MYSTERY MARKINGS FOUND???????
