79' fan relay or resistor?
Dark Blue wire between resistor and relay: 4.2V?
Purple wire: 11.2V
tan and light blue wires 7.8v?
I did clean all relay and resistor connectors but wouldn't doubt possibly an issue with the old wiring.
Do local GM dealers or auto parts stores carry these relays and if so what's the p/n? Can someone with experience here please chime in?
I'm not sure what I posted before, but here is a schematic from the web site:
I like this one because it has numbers
So, here we go! The resistor show above as AC Resistor is what controls the motor speed on everything but high. You first need to verify that each of the three wires 50, 63 and 72 have 12 volts on them before the resistor when the switch is in the following positions. Brown number 50 is low speed. So when your switch in the heater control is on low speed this wire will have 12 volts. (before it enters the resistor).
Tan number 63 is the number 1 speed. So when you switch to the first click on the blower switch in the dash this wire should have 12 volts on it. (before it enters the resistor).
Light Blue 72 is the number 2 speed. so when you switch to the second click on the blower switch in the dash this wire should have 12 volts on it.
Now... keep in mind that all lower end speeds go through the resistor. And that high is direct.
Once you have tested the three wires before the resistor... go back to the dark blue wire and see if the output voltage changes. When you test the voltage on the dark blue wire it should increase the higher speed you put the motor on until you reach high.
On high speed... you should have voltage present on the orange wire.
Post back...
Willcox
Now to tackle the vents operation so I'll be back.
Thank you for the kind words and I'm glad you figured this out.
Willcox
