Emblem
Old Aug 9, 2011 | 04:51 AM
Cannon Skier's Avatar
Cannon Skier
4th Gear
Default Emblem
I want to remove the front emblem of 1980, any suggestions? Thanks
Old Aug 9, 2011 | 10:16 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Check the under side for speed nuts. Use a slim blade putty knife on the emblem adhesive.
Old Aug 9, 2011 | 01:36 PM
7T1vette's Avatar
7T1vette
If that emblem is stuck on with double-sided tape, then buy some dental floss (waxed type) and use it to slice through the tape while 'sawing' it back & forth with your hands. It should come off easily and the dental floss won't damage the paint.
Old Aug 9, 2011 | 01:45 PM
DRIVESHAFT's Avatar
DRIVESHAFT
It is just tape holding it on an '80 model.
I used fishing line, sort of like the dental floss mentioned above.
In my case it was a pain to get it off.
To Emblem
