My power steering just started to whine really badly - mainly when I am turning - but also upon starting the engine. I looked at the pump and can't seem to located a place to put fluid in... am I missing something?
Sounds like you have a leak. There can be several sources for a power steering leak. You need to get under the car and find out where you are losing fluid.
You want to fill the reservoir so that the fluid comes to the COLD mark on the stick on the reservoir cap.
You don't want to overfill. When the system heats up and the fluid expands, you want the fluid to remain in the reservoir not overflow out of the reservoir.
