Window goes up too far!
Old Aug 13, 2011 | 11:55 AM
retaf's Avatar
retaf
Default Window goes up too far!
I have power windows on my 79 and have performed the adjustments per shop manual and AIM yet driver's side still goes up about 1/4" too far. Could something be worn or is there a trick to this? These windows are a real PITA!
Old Aug 13, 2011 | 12:34 PM
Alan 71's Avatar
Alan 71
Hi r,
As part of your adjustment procedure did you set the upper stop in the top of each of the 2 vertical tracks per side?
Regards,
Alan
Old Aug 13, 2011 | 12:45 PM
retaf's Avatar
retaf
Originally Posted by Alan 71
Hi r,
Regards,
Alan
Yes I did but I will recheck that again....
Old Aug 13, 2011 | 04:17 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Lowering the window stops in the run channels should solve the problem.
Old Aug 14, 2011 | 06:08 AM
parkerracing's Avatar
parkerracing
Be happy, most of them don't go up far enough. /:\
Old Aug 14, 2011 | 11:29 AM
BBCorv70's Avatar
BBCorv70
Hi r,
Regards,
Alan
I see no way they could go too far up if the stops are set correctly.
Old Aug 14, 2011 | 06:33 PM
retaf's Avatar
retaf
I got the window height and all other adjustments fine tuned now. I've been messing with the windows for several days and finally figured out everything through trial and error. I think I could adjust them blind folded now. They're not perfect but as close as it gets without taking all the guts out and replacing a lot of parts which is not my plan right now. Thanks for everyone's comments....
To Window goes up too far!
