Im fairly new here ,hopefully someone can help,it's likely a common question.
The right head light does not come up left works well,I have change both vacuum relay and all the hoses,but still nothing
thanks in advance~
Hi Charles,
The headlights can be a bit of a puzzle.
Have you tried to open it by hand to see if the door mechanism itself is operating?
It's best to disconnect both hoses from the actuator when you do this so you don't put any stress on the diaphragm in the actuator.
This test will tell you if you have a mechanical or vacuum problem.
Regards,
Alan
thanks in advance~
Charles
It is a very common question. That's why the forum has that Search function available.
If you changed all the hoses and both relays then the problem might be the seal in the actuators.
Here's a "How to test": http://www.corvette-101.com/vacuum.htm#actuator
Heres what the parts look like, a lot of the time the center part is bad.
Thanks for the info ,I will print and keep.I tried all the test in the instructions all was ok.I finaly disconnected all the hose on the right side ,pulled the headlight manualy ,reconnected the vac. hoses started the car and it works perfect ,I dont know what the problem was but its fine now
Thanks Again
From: Melbourne, Fla. 6 months- New Middletown, Ohio 6 months
Lubricate all the linkage, it may of just been in enough of a bind that the vacuum could not overcome the resistance. When you manually opened it you may of freed it a bit. Could happen again.
