What's in a ZZ4?
Old Apr 29, 2002 | 02:40 PM
Koz
Guest
Posts: n/a
Default What's in a ZZ4?
What Cam, Heads, Pistons, etc.. come with a 350 ZZ4? Is it really cheaper to buy a ZZ4 than build up your own motor?
Old Apr 29, 2002 | 03:09 PM
FeedVaal's Avatar
FeedVaal
Default Re: What's in a ZZ4? (Koz)
http://www.westcoastsportscars.com/zz4.html
Probably a little cheaper to rebuild old motor but ZZ4 comes practically complete and with a warranty.
Old Apr 29, 2002 | 03:16 PM
79MakoL82's Avatar
79MakoL82
ZZ4 has a 4 bolt main, forged steel crank, Hypereutectic pistons, cam specs: hydraulic roller cam Lift .474" intake, .510" exhaust. Duration @ .050: .208° intake, .221° , L98 almuminum heads.
Those are some damn fine internals that can be had for about $3,400. Hard to build a motor yourself with forged steel crank, aluminum heads and roller cam for less. Also, don't forget the 1 year warranty on the ZZ4.
[Modified by 79MakoL82, 1:24 PM 4/29/2002]
Old Apr 29, 2002 | 03:57 PM
ddecart's Avatar
ddecart
SPARTAN
CI 3-4-5-6-8-9-10 Vet
CI-9 AutoX Winner
CI-3 Go Kart Champ
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
This is what's in it: https://www.spoperformanceparts.com/store/catalog/Product.jhtml?PRODID=1103&CATID=1099
ZZ4 Technical Information
Horsepower 355 @ 5250 RPM
Torque 405 @ 3500 RPM
Max. Recommended RPM 5800
Compression Ratio 10:1
Block 10105123 Four bolt main, cast iron
Crankshaft 12556307 Forged steel
Connecting Rods 10108688 PM rods
Pistons 10159436 High Silicon aluminum with offset pins
Piston Rings 12528817
Camshaft 10185071 Hydraulic roller
Lift .47" I, .510" E.
Duration @ .050:208º I, .221º E.
Intake Manifold 10185063 aluminum dual plane
Distributor 1104067 HEI
Cylinder Heads 12556463 Aluminum 58cc combustion chambers
Intake Valves 10168465 1.94"
Exhaust Valves 10168514 1.50"
Valve Springs 12551483 LT4 chrome silicon
Rocker Arms 10089648 1.5 ratio
Valve Lash Zero
Spark Plugs FR5LS Gap .035
RapidFire #5 Gap .045
Fuel 92 Octane
Ignition Timing 10 BTDC @ 4000 RPM
32º total @4000 RPM with vacuum advance disconnected
Technical Notes: Carburetor, spark plug wires, starter, oil filter and oil filter adapter, and exhaust manifolds not included. Distributor P/N 1104067 or melonized distributor gear P/N 10456413 must be used on all crate engines with steel camshafts.
Old Apr 29, 2002 | 03:58 PM
tshort's Avatar
tshort
CI 7-8 Veteran
Default Re: What's in a ZZ4? (79MakoL82)
What kind of power can you expect from a ZZ4 with an average street aluminum intake and a 650 double pumper? Or does a ZZ4 come with intake and carb?
Old Apr 29, 2002 | 04:50 PM
Scooter70's Avatar
Scooter70
Default Re: What's in a ZZ4? (tshort)
Comes with intake as listed above. You provide the carb. GM says 355hp@5250/405ft-lbs@3500.
Old Apr 29, 2002 | 04:52 PM
Cruzmeisters's Avatar
Cruzmeisters
Comes with intake, but no carb; comes with spark plugs, but no wires; comes with long shaft water pump, you need "short shaft"; comes with flex-plate for auto trannies, "sticks" need a different flywheel. Also needs starter and fuel pump. Am I correct, Oh Wiser Gear-Heads? :confused:
Cruz
Old Apr 29, 2002 | 05:45 PM
Mack's Avatar
Mack
Default Re: What's in a ZZ4? (Cruzmeisters)
Cruz
Yep... I belive you nailed it. :yesnod: Sticks can't use their old flywheel 'cause the bolt circle's different.
Old Apr 30, 2002 | 01:15 AM
theandies's Avatar
theandies
Default Re: What's in a ZZ4? (Mack76)
Also the biggest thing IMO is every part in the engine is brand new...including the block.
John
To What's in a ZZ4?
