another vett that wont start
Old Aug 20, 2011 | 09:33 PM
Legacy Stables's Avatar
Legacy Stables
Default another vett that wont start
I have purchase a 76 that doesn’t start I have eliminated some things. but the starter act like there is no power.
I have a good working battery
the ground cable has been replace
the starter has been benched and does work
I have power getting to the main terminal on the starter
the starter doesn’t do anything when the you try to start the car
fuses are fine but I will replace any way when that comes in the mail
the steering column lever is pushing on the switch so the sector gear is good
this leaves two possibilities there a bad wire or the column switch is bad or ?
what can I do to test these with out tearing apart the harness or pulling the column any advice?
Old Aug 20, 2011 | 09:39 PM
'75's Avatar
'75
Do you have normal accesssories working with the key on, ie radio, gauges, windshield wipers? If so, you may have a problem with the neutral start switch if it's an automatic trans or clutch switch if manual trans. If no accessories work, may be a fusable link burnt out.
Old Aug 21, 2011 | 06:47 PM
Legacy Stables
other than the parking brake light and an annoying buzzer I have no lights, wipers, ect but I thought that was a bad ground.
I have heard of fusable links in the harness but have no Idea what they are or their purpose hopefully some one can chime in. looks like I will start unhooking the harness to test it out.
Old Aug 21, 2011 | 08:17 PM
'75's Avatar
'75
You can get a download of the electrical schematic here http://www.nrjvette.com/johdotukset/?C=D;O=D
Old Aug 21, 2011 | 09:10 PM
Legacy Stables
Consider this post closed
after running another 12v line to the starter and started cranking I have found out there is no fuel getting to the carb and no power to the spark plugs
so I have to pull the harness and fix it or replace it and I will have to troubleshoot the fuel system next
thanks for the input.
To another vett that wont start
