Need help with Auto Trans problem
Old Apr 29, 2002 | 07:21 PM
BTRNSEX's Avatar
BTRNSEX
Default Need help with Auto Trans problem
79 L-82 w/auto trans
When put in gear the trans makes a 1/16th turn counter clockwise and then rotates 1/8th turn clockwise as it engages causing a thump. Could this be caused by the modulator?
Any info would be helpfull at this point.
U-joints and yokes are sound for now, but at this rate they won't be for long.
Thanks Roy
[Modified by BTRNSEX, 5:43 PM 4/29/2002]
Old Apr 29, 2002 | 07:56 PM
nunus79's Avatar
nunus79
Default Re: Need help with Auto Trans problem (BTRNSEX)
From where are you measuring the amount of trans turning? All I can imagine is that both the engine and the transmission as a unit is torquing over. If that is the case, check your motor mounts. Hope this helps????
Old Apr 29, 2002 | 08:09 PM
BTRNSEX's Avatar
BTRNSEX
Default Re: Need help with Auto Trans problem (nunus79)
Measuring at output shaft on tranny. Strang huh. All mounts are new, first thing I checked.
Old May 2, 2002 | 10:13 AM
BTRNSEX's Avatar
BTRNSEX
ttt
To Need help with Auto Trans problem
