Aftermarket AC advice
Old Aug 22, 2011 | 08:59 AM
myc3's Avatar
myc3
Default Aftermarket AC advice
I intend to install either a Vintage Air or HotRod Air AC system in my 77 when the new engine is installed. Currently the engine compartment is empty and the radiator and condenser have been removed.
I have 2 questions:
Which system would you choose and why.
What other parts should be removed prior to installation (i.e evaporator box?).
Old Aug 22, 2011 | 10:10 AM
Gordonm's Avatar
Gordonm
Vintage Air is going in mine. Reasons are reputation, customer service, other forum members success stories, personal experience of seeing one installed and working with system. No experience with Hot Rod air so I cannot comment on them.
Old Aug 22, 2011 | 10:18 AM
rugerm44's Avatar
rugerm44
Do a search.Good amount of information on the vintageair system.There is a few pains installing it but over all I haven't had any issues with it afterwards.
Old Aug 22, 2011 | 10:25 PM
redwingvette's Avatar
redwingvette
I bought my system from http://www.nostalgicairparts.com/
I all ready had air so I did not buy the full system.
I have yet to get it charged but everything fit nice and they were very helpful on the phone.
Old Aug 22, 2011 | 10:33 PM
shrekviper's Avatar
shrekviper
You'll have to remove the dash to get these installed. The biggest PIA w/ Vintage Air is getting the outlet hoses routed and getting the dash back in. It's not a complex install. If I can do it, it's not impossible.
Old Aug 22, 2011 | 10:41 PM
speedreed8's Avatar
speedreed8
vintage air install by F/M (ajrothm), lots of pics.
http://forums.corvetteforum.com/c3-t...-begins-2.html
http://forums.corvetteforum.com/c3-t...tall-pics.html
Old Aug 23, 2011 | 11:05 AM
Rotonda's Avatar
Rotonda
Default Vintage Air into a 77
I put a Vintage Air into my 77. The Vintage Air kit is intended for C3's up to 77, with the first style dash and controls. To make it work:
1) I substituted Vintage Air's 3 **** rotary control for all of the parts in the kit that convert the 68-76 stock rotary controls. TO DO THIS, THE UNIT YOU ORDER WILL NEED A DIFFERENT ECM. TALK TO VINTAGE AIR. The Vintage controls mount into a plate (you must fabricate) that covers the original rectangular control cut out.
2) The center dash outlet in the 77 is completely different from earlier years. I fabbed an adapter for this that also moved the two inlet hoses from the back to the left side of the center stack.
Everything else generally installs as per the Vintage Air instructions, though I made a number of other mods. If you need more info or pics of the two mods described above, PM me.
Old Aug 23, 2011 | 11:13 AM
Corey_68's Avatar
Corey_68
Vintage Air
We have installed around 8-9 VA units in various customer cars without issue and is what I'm installing in mine.
Old Nov 21, 2018 | 02:34 PM
possumd's Avatar
possumd
Navigator
Default Zip air
any thoughts on the Zip a/c products? For installation in a '74 ? It looks like they're made some mods that reduce the amount of space in the engine bay.
Old Nov 21, 2018 | 08:15 PM
7T1vette's Avatar
7T1vette
If you have a non-A/C car, I would suggest the Vintage Air route. If you have an A/C car and still have the evaporator core and casing in place, a Classic Car Air conversion kit would be the way to go. (but I think you have a non-A/C car.....)
Old Nov 21, 2018 | 08:18 PM
lsintampa's Avatar
lsintampa
I did a VA in my 75. All I can say is it wasn't easy, but it blows very cold. Being in FL, that means a lot.
Old Nov 21, 2018 | 08:22 PM
BLUE1972's Avatar
BLUE1972
I did the Vintage Air in my 71, it was not that bad. I did use reduced size hoses on the center outlets = Vacuum cleaner hoses.
It does blow very cold …
Old Nov 21, 2018 | 10:27 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
Can we not start a new thread vs a zombie?
Old Nov 24, 2018 | 11:28 AM
possumd's Avatar
possumd
Navigator
it has ac but the compressor is gone who knows what else........i'm looking at it today i hope. Can the condenser come out be checked or flushed? If all the other crap is still in the car, can everything be flushed to clean any dirt and misc out?
Old Nov 25, 2018 | 08:47 AM
BLUE1972's Avatar
BLUE1972
yes the system can be flushed. The factory system works ok, the Vintage Air system works better. For the cost of rehabbing the factory system it may pay to go with the aftermarket unit.
Old Nov 25, 2018 | 09:19 AM
ndmick's Avatar
ndmick
I also have been looking to do this and have decided to go with vintage air for my 71 coupe.Where would be the best deal buying a vintage air system? Is there a better time of year?Thanks.
Old Nov 25, 2018 | 02:28 PM
possumd's Avatar
possumd
Navigator
the VA aftermarket used the R4 shorty compressor?......how many changes need to be made?
Old Nov 25, 2018 | 07:11 PM
SteveG75's Avatar
SteveG75
Zip sells the Vintage Air products. Might as well buy direct from VA for the customer service.
To Aftermarket AC advice
