Temperature sender?
Old Apr 29, 2002 | 07:59 PM
corvette4life's Avatar
corvette4life
Default Temperature sender?
I put vortec heads on my 78 corvette. The hole in the head is for a smaller sending unit. I got one from G.M. that fits the head but now the gauge reads about 40 degrees to cool. Anyone know of a sending unit that will read right?
Thanks,
Kerry
Old Apr 30, 2002 | 01:14 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default Re: Temperature sender? (corvette4life)
I have the same problem with my 1980 Duntov Turbo... I got a new sensor and it shows approx. 40 - 50 degrees too low temperature... I am curioius to see some answers here!
:cheers:
Old Apr 30, 2002 | 02:46 AM
73 LS-4's Avatar
73 LS-4
All I can say is good luck finding one that reads right. I had a hard time finding a correct reading one on my 73. I eventually gave up and made the old one work (tang broke off).
:cheers:
Pat Kunz
Old Apr 30, 2002 | 11:58 AM
Bill W's Avatar
Bill W
Mine reads 45 degrees hihger than actual. You may end up having to put a resistor in line to correct for it. You can search the archives. Many threads on this subject.
Old Apr 30, 2002 | 09:38 PM
corvette4life
ttt
To Temperature sender?
