'72 mystery wire, washer pump?
Old Aug 23, 2011 | 06:44 PM
AZDoug's Avatar
AZDoug
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
Default '72 mystery wire, washer pump?
I have a broken off wire (blue green insulation) and I believe it connects to the front of the wiper motor under a black plastic cover on the motor, there is a yellow wire opposite where I believe the blue wire goes, does this sound right? Connector seems to be a funky round male connector as you would find an aftermarket car stereo, not a typical GM type spade type connector.
Thanks,
Doug
Old Aug 23, 2011 | 06:59 PM
Alan 71's Avatar
Alan 71
Hi Doug,
Yes, the blue wire enters from the right side, and the yellow opposite it, from the left side. The both have a round 'barrel'? connector crimped to the end of the wire.
Regards,
Alan
You can see the blue wire in this picture.
And the yellow wire in this picture.
Old Aug 23, 2011 | 07:49 PM
AZDoug's Avatar
AZDoug
Thats it, I see that mine has the wires reversed.
Thanks,
Doug
Old Aug 23, 2011 | 10:12 PM
Mashman's Avatar
Mashman
Thanks,
Doug
I just checked my 72, and mine also has the yellow wire on the passenger side. I don't believe the wires are long enough to be reversed, so I'm pretty sure that is correct for 72's.
To '72 mystery wire, washer pump?
