Horsepower gains
If you have an automatic , I'd suggest a 700R as your first step.
The 700R has a 30% steeper gear. Turns your 3:55 gears into 4:60 gears when in first. Turns your 3:55 gears into 2.40s on the highway. You can lay a 60ft patch on the strip and still get 24mpg (or better) I got 26mpg with my 350. Pulled it out and stuck in a 383 and get 24mpg now.
OK, this is where I have to say something. Torque is a static rotational force until combined with rpm, then the measurement of this combination is horsepower. Torque x RPM / 5252 = Horsepower. Don't believe me, clamp your torque wrench in your vise and pull it up to 300 ft lb. How fast is your vise going? Horsepower is the work being done, moving your car is the work. People confuse strong bottom end with torque and a strong top end as horsepower. It is always horsepower if there is work being done. The best way to make a quick street car is to make strong torque over a wide RPM range, from bottom to top. The higher in RPM you can maintain your torque, the more horsepower you make. 400 lb ft of torque at 2500 rpm will move your car exactly half as quickly as it will with 400 lb ft of torque at 5000 rpm. That would be 190.4 HP at 2500 and 380.8 HP at 5000. The best way to get your tail whipped is to make all your torque in the bottom end and go up against a car that has made a wide power band or has moved the torque towards the higher rpm. If you have moved the torque towards the top all you have to do is gear and drive it appropriately to make use of the power-band. As I said before though, wide power-bands over a broad rpm range will be the best for the street.
And I say"
When someone extols a need for torque and not horsepower, they are a bit lost.
V2 just seemed to be letting them in on reality, IMO.
Really??? Well you can't put air in a tire unless there is a tire,common useless knowledge.
When people say they have double hump heads do they say 300 horse heads or 125 lbs torque heads????
Its just irreverent to bring torque up all the time ain't it??????
Professional engine designers and builders look at the torque curve to match the power bands to the needs of the engine's use. Torque is never irrelevant, but neither is horsepower. Just as Driveshaft has said, they are inseparable. This is my main point, nothing more.
I'm not going to comment on this again. We have hijacked the OP's thread. There is some good sound advice on how to get power in this thread, including yours Tim!
Cheapest way on a 350 would be to do a Vortec head/intake swap with the upgraded springs/machine work. Then do a nice modern style cam like a XE268 or Lunati Voodoo equivilant...something in the 224/228 range with around .525-.550 lift on a 110lsa. All of this should net you around 380-400 crank HP ASSUMING your engine is very healthly before you start modding it.... I would probably mill the heads a bit and use a .030 MLS layered head gasket to try to bump the compression up some....You are likely in the sub 8-1 compression range.... You can't gain much without a piston swap but.... you can probably get an honest 8.5-8.7:1 with milling and thin head gasket.
First and foremost, do a compression and leak down test to determine if your engine is still sealing well enough to even mess with it.....If not, youre wasting money bolting on new parts.
The L82 is kind of over-cammed with the stock intake and exhaust manifolds, a Performer RPM style intake, headers and 2 1/2" dual exhaust, re-curve the distributor and tune the carb, probably make a huge difference in the seat of the pants.
Put forth the time and effort to make sure you have an engine that is worth bolting speed parts onto, I.E. compression and leak down test. If you are replacing the heads, you're only really worried about the ring seal, since you are putting fresh heads on.
Scott
Scott
For sure lets stay away from telling him what kind of oil to use or if he should use ethonol based fuel
I say "know your audience if you're going to answer a question".
Our OP joined in Aug 2011. He has a '74 vette. So I'm guessing hes a young guy , maybe in his 20s ,new to corvettes. When I was a young guy a LONG LONG LONG time ago , I would have asked the same thing.
I just wanted to throw something out there for him to think about.
Now if someone was to ask the same question and they were a member here for 15yrs with a BB 502 , well maybe I'd have a different response.
Either way , hopefully someone will look at the responses and take something away from it. Even if its just going on the net and digging into what torque and hp really mean.
Scott
Recurve your distributor so that the mechanical advance is "all in" by whatever RPM is your highway cruise RPM. Make it total (initial plus centrifugal) about 34 degrees (before any vacuum advance). After you have done that, connect your vacuum advance so that it runs full time. You will need to readjust your idle speed.
Put in an oversize K&N air filter. The stock '74 air filter element is very short- you can put in a taller one one designed to fit a '77, and get a longer 1/4-20 stud to hold down the cover. It'll fit.
Also, the stock fuel filter on a '74 is tiny. You can get a longer inlet nut (from a '77 or so) and double the filter in size, without looking too different from stock.
You want to run a truck sized engine oil filter.
Those are cheap modifications.
And a true 2 1/2" exhaust, with high flowing mufflers, will definitely help.
Anyone noticed the OP hasn't chimed in. Are we just arguing with ourselves ?
Any K&N 'oversize' filter has an equivalent paper filter, if you believe you need more filtering area. I have to laugh to myself whenever I see K&N recommended. Back when I was younger, K&N made their mark (whatever that was) by convincing ricers that they could get anywhere between 5-25 HP more by using K&N. Usually not true, but .... This idea soon spread to the Hot Rod community, mainly the younger members. Put YOUR car on a dyno, switch out the air filter, and see how much YOU gain. Oh yea, put a K&N filter top on your air cleaner, as opposed to running a stock cold air induction system, and see how much you gain from sucking in the hot under hood air. Use actual dyno, not butt dyno, numbers.
I'm waiting for the numbers.
Hmmmmm..............methinks we may have been hoodwinked!!!!! Just another bogus post to drum up the post numbers to make the advertisers happy?
Scott
Heres a down to earth answer, tune your distributar to 36 degrees at 3000RPM, free flowing air cleaner, gap your spark plugs to .040.
Then headers and new exhaust with your choice of just about any aftermarket muffler as long as its not stock. (shameless plug for Flowmasters)!
Then a good hi rise intake, (not performer style) prefer the Summit brand or Professional Products if you like saving money.
Holley Carb, 650 Double pump with manual trans, 750 vacuum secondary with auto.
This is just a start.
If you can't feel more power in the seat of your pants then just sit in front of the computer and do mathematical equations until you figure out how to incorporate nuclear fusion into your engine.
To the OP headers, manifold and 650 Holley lose all the smog equipment might be the answer. A rear gear change will make it feel like it has more power.
When I built my 427ci small block I wasn't building it to make 500TQ I was building it to make 600+Hp and low and behold there's plenty of torque there
I do however kind of agree a 350ci needs torque, kinda a bandaid for a small ci motor but it is relatively easy to get some torque out of it. I got 330Ft/lb and 295HP from my warmed over L48 at the rear wheels
My 427ci. Over 300Tq at the rear wheels when he stepped on the gas at 2000RPM on chassis dyno
My previous 406ci was shooting for 500+HP, this was an engine dyno I got numerical printout so I plotted them
Forum member, Karol, who has a basically stock 100,000 mile ( that's right!) L-82 engine with a Performer intake, OEM Q-Jet, cam of unknown origin in the OEM stock 882 smog heads, NO headers but 2.5 true duals with Magnaflows just dynoed his car AND:
248 and change RWHP, NOT Net, NOT Gross. That is abut 290-300 Net HP
That would be an 80 HP increase over the 220 Net HP stock rating on a 100,000 motor! 80 HP with the smog heads on a hot humid day!!
Changing heads with a decent cam, the L-82 will make over 400 Gross HP! It's been done and documented-easy!
http://www.amazon.com/gp/product/B00...CS81RGM0YS044E
http://www.amazon.com/gp/product/B000LUBUJY/ref=pd_lpo_k2_dp_sr_1?pf_rd_p=486539851& pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B000LU8QUK&pf_rd_m =ATVPDKIKX0DER&pf_rd_r=1316M3CS81RGM0YS0 44E
A 305ci in a 79 Cutlass can handle a 750 Vacuum carb.
Got to put more air in if you want more air out.
