Why DeWitts?
Old Sep 3, 2011 | 07:11 PM
  #61
eagle275's Avatar
eagle275
Wow, I didn't know all that technology and work went into making a radiator. Thanks Tom!
Old Sep 30, 2011 | 12:03 PM
  #62
pyro454's Avatar
pyro454
Originally Posted by spinadog
I have the edelbrock aluminum one sprayed Chevrolet orange and it looks just fine - close to stock. My original was not - some cheap reproduction junk someone swapped in there a while back.
Thanks for your input. I ordered the edelbrock polished one and my Dewitt's rad just showed up. Definitely worth the extra money! Now do I paint the side tanks and top black or just leave the bare almumimum?
Old Sep 30, 2011 | 05:41 PM
  #63
Tim H's Avatar
Tim H
You know if you paint a radiator that traps the heat in.
Old Sep 30, 2011 | 05:55 PM
  #64
pyro454's Avatar
pyro454
Correct, I have read the theory behind it and that's why I would just paint the side tanks and the top to try and maintain some of the stock look of the 70 vette. (Anything is better than the existing painted copper rad I have for cooling though)
Old Sep 30, 2011 | 06:10 PM
  #65
Tim H's Avatar
Tim H
I think there is paint out there just to paint the whole radiator, maybe Eastwoods.
Old Sep 30, 2011 | 06:56 PM
  #66
pauldana's Avatar
pauldana
Tom and I have been talking off and on for the past couple of weeks. And I think it should be noted that he is coming out with a larger core radiator that will cool about 20% better than anything else i am aware of out there. I believe this to be very important...jmho....just a fyi
Old Oct 1, 2011 | 10:44 AM
  #67
pyro454's Avatar
pyro454
Paul, you should have told me that 4 weeks ago! lol
Old Oct 1, 2011 | 11:42 AM
  #68
RobbSalzmann's Avatar
RobbSalzmann
St. Jude Donor '12
Tom,
Are you able to supply a rad for 77 M/T with threaded bungs in place of the 1 1/2" hose barbs? I need the bungs to accept -20AN fittings (bottom threaded portion shown threads into rad):
Old Oct 1, 2011 | 03:34 PM
  #69
Paul L's Avatar
Paul L
I would like to hear Tom DeWitt's comments on painting a rad and any impact on efficiency of cooling. He does offer a paint option.
Old Oct 1, 2011 | 09:43 PM
  #70
pauldana's Avatar
pauldana
Just found out myself.... but this may make me switch to Tom's unit... i am very interested in the 20% greater cooling power...
Old Dec 18, 2011 | 03:37 AM
  #71
2box's Avatar
2box
Default End of the year sale
Originally Posted by Tom DeWitt
Thanks for the comments guys. Maybe we should consider a CF open house for next year?
Are You guys having one or Do You plan on having some sort of sale any time soon? Your radiator for my 79 would be a very nice christmas present......
Old Dec 19, 2011 | 07:12 PM
  #72
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
Yes we are going to post one in January. I don't want to start it now because we do not have anyone at work to build them and I want to be ready to go with people and parts.
I just noticed the Paint questions so I can answer that too. We see no reduction in heat transfer with a spray painted radiator as most of the paint goes onto the end tanks and the rails. The core section is the only part that actually removes heat and spray tends to go right through without coating anything. The only way you could ruin a radiator is if you were to dip paint the radiator. This would fill the fin and louvers with paint.
Old Dec 19, 2011 | 07:21 PM
  #73
Tim H's Avatar
Tim H
Radiator Black 12 oz Satin Finish
Item #10340 Z
In Stock - Ready to Ship Today
Only $14.99
Buy 2 or more for $14.29 each and save 5%
Buy 3 or more for $13.49 each and save 11%
Radiator Black Satin Paint is the perfect viscosity to spray-paint your radiator without damaging it
Standard engine paints are too thick for use on a radiator because they can interfere with heat transfer, and block air flow between the cooling fins. But Radiator Black Satin is formulated specifically for your radiator, heater core and air conditioning condenser.
Won't block air flow between cooling fins
Won't interfere with heat transfer
Acrylic enamel
Withstands 300 degrees F
Qty: 1
$14.99
Old Dec 19, 2011 | 07:30 PM
  #74
Paul L's Avatar
Paul L
A voice of knowledge and reason. How can a thin coat of black paint affect heat transfer?
Old Dec 19, 2011 | 07:33 PM
  #75
Tim H's Avatar
Tim H
Go get you some 99cent walmart paint and pull your rad.
Sit it in front of a big fan and feel the air, then give it a good coat of the paint, let dry and sit in front of the fan again and tell me your pre over heating results.
Old Dec 19, 2011 | 07:40 PM
  #76
Paul L's Avatar
Paul L
I don't shop at WalMart. My 1974 with a 180*F t-stat and black GM rad runs 180*F at 60mph and may climb to 200*F in city driving. That is at 85*F ambient. You have an interesting but very strange argument.
On more serious matters, Tom I look forward to your offer in the New Year. I have a friend who may need a C3 rad.
Old Dec 19, 2011 | 07:48 PM
  #77
Tim H's Avatar
Tim H
Its not my argument its Eastwoods, I just agree with it.
Long johns make you warmer under pants and 200 degrees isn't that cool, mine won't reach 185 sitting in traffic.
To Why DeWitts?
Old Dec 19, 2011 | 08:09 PM
  #78
Paul L's Avatar
Paul L
This is so old it is ludicrous. And I don't know how many times this subject has to be thrashed out. But here goes.
I drove a 1979 for 17 years. The GM t-stat was 195*F and it ran generally around 200*F. The cat con is designed for those temps. At times it would go to 215*F or so at highway speeds. No problem. It had an auxiliary electrical fan that kicked in at 238*F, that was a GM design I believe for towing or track work. The red line was 260*F.
The boiling point of water is 212*F. The boiling point of a sealed/pressurized system with anti-freeze (50:50) and a 15psi rad cap is much higher. So what is the fascination with a bit of paint and 185*F temps? It's trivia. The old GM V8 can and works very well at much higher temps. And for some years was designed to do so.
Old Dec 19, 2011 | 09:33 PM
  #79
69VetteFla's Avatar
69VetteFla
Might pull the trigger for the Jan sale
Old Dec 20, 2011 | 07:27 AM
  #80
Tim H's Avatar
Tim H
You can post scientific facts all you want then tell the guy why his car runs 220 on the highway?
Thick paint clogs the fins whether you believe it or not.
Im sorry you have painted yours and now wish you didn't do it so you try and talk yourself into thinking its alright, but Eastwood says thick paint will clog the fins so it will, they are as smart there as anyone here.
