Why DeWitts?
Old Jan 1, 2012 | 05:20 PM
  #101
C3Paul's Avatar
C3Paul
Originally Posted by aussiejohn
C3Paul,
The engine will not run cooler than the temperature at which the thermostat is designed to open.
Regards from Down Under.
aussiejohn
Got it, thank you! (Of course, I am being an idiot! Thermostat)
but:
What 'Lb' pressure cap do I need? is it 15psi
What size diameter is the upper tube for the upper hose? Is it 1.1/4”
Again 1980, Manual car
Old Jan 1, 2012 | 07:55 PM
  #102
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
What size diameter is the upper tube for the upper hose? Is it 1 1/4”
The pressure cap rating has very little to do with how your system is going to work. Pressurizing the cooling system only raises the point at which your coolant will boil. A 50/50 mix will boil at about 240f and when you pressurize you gain 3 degrees for every 1 psi. So a 15psi cap will increase the boiling point 45 degrees for a total of 285.
So if your system is working as it should and you run between 180-200 degrees, you don't even need a cap. It's actually pretty silly when people change from a 12# to a 15# or whatever. Why would this matter?
The upper connection on the 77-79 is 1.5" and the 80-82 is 1.25" otherwise the radiators are identical for that group. We use a combination neck that incorporates both sizes.
Old Jan 1, 2012 | 08:04 PM
  #103
Paul L's Avatar
Paul L
Originally Posted by Tom DeWitt
free for 48 states only, but we could give Alaska and Hawaii memeber some kind of shipping discount as well as our friends in Canada.
The rules require all order go through our website. We'll post up all the requirements like every year.
As usual Canada seems to be left out. UPS/FedeEx does our routes the same as US.
Old Jan 1, 2012 | 08:21 PM
  #104
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
You probably didn't know UPS adds brokerage fees to our bill that you would never see.
Old Jan 2, 2012 | 05:55 AM
  #105
C3Paul's Avatar
C3Paul
Great,
Count me in for:
1x 1980 Manual radiator with 1.25" tubes.
Free shipping to friends in UK
Old Jan 2, 2012 | 05:38 PM
  #106
Deandarien's Avatar
Deandarien
Just bought a 1978 L82 looks to have a new rad but it leaks........do the DeWitts have the name stamped on the radiator or some other marking? Looks to be a 4 core. Droped it off at the shop today. Looks like I know what to go with if they scrap it!
Old Jan 2, 2012 | 05:43 PM
  #107
Paul L's Avatar
Paul L
I did not know that and can't understand why. I certainly feel the UPS brokerage sting at the consumer end. And it is outrageous. But a vendor paying brokerage?
Old Jan 3, 2012 | 01:02 PM
  #108
Condo_454C3's Avatar
Condo_454C3
Not diameter but tube width, the tubes are flat. Most of the aftermarket aluminum radiators are two rows of 1" wide tubes, often incorrectly called "cores".
First I should say the copper radiators used during the C3 era are huge in size compared to other groups and in most cases a good functioning copper unit will work fine.
When you upgrade to an aluminum radiator it is like adding length to the radiator without changing its size. 30% for the 1" tubes and 35% for the 1.25" tubes. That's a lot when you think of it this way...if your copper core was 30" the aluminum 1" version would cool like 39", while the 1.25" would be like a 41". So, the large tubes do add more but not a lot in comparison to the jump from copper to aluminum. Hope that makes sense?
The cost for the larger tubes is $75 and when the January sale starts that is about the same as the discount. So you could get the fatter tubes for the same regular price.
The sale will start January 16th and run the restof the month. 15% discount and free shipping, which amounts to about $125 savings.
Thanks very much for that well-written explanation, it helped a lot. Come the 16th I'll be ordering the alum rad/dual fan combo with the 1.25" tubes
Old Jan 5, 2012 | 09:38 AM
  #109
07blkvette's Avatar
07blkvette
When does the sale start in January, with 20% off and free shipping?
Old Jan 5, 2012 | 12:55 PM
  #110
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
It starts on the 16th and the discount is 15% with free shipping. I will post it when we have everything ready to go.
Old Jan 6, 2012 | 08:56 AM
  #111
C3Paul's Avatar
C3Paul
Tom,
Can you pm me I need to discuss my order and UK customs, please.
Old Jan 6, 2012 | 06:04 PM
  #112
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
Tom,
I don't use PM but if you want to email me tom@dewitts.com we can discuss it
Old Jan 6, 2012 | 06:58 PM
  #113
LAddams's Avatar
LAddams
Which sale is better January or Carlisle?
Old Jan 6, 2012 | 08:47 PM
  #114
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Originally Posted by 69FASTFUN
I just received my radiator from Dewitts for my 69 and I got the black ice it looks great. I can hardly wait to see if it does cool down my 427. I also received a radiator for my 72 for a later restoration project.
Thanks Tom for your great radiators
I got the same radiator (black) a couple years ago for my '69. Ran a 99* track day in Topeka last July, and no overtemp problems at all. While I like to think that part of the success is that I've got the engine running efficiently over RPM and load, I have to admit that the radiator is a quality piece and did its job.
Don't sweat the paint issue.
Old Jan 15, 2012 | 08:14 PM
  #115
BillyTz06's Avatar
BillyTz06
Is the big sale still going to start tomorrow ? Please make a post if it is !!! Thanks
Old Jan 15, 2012 | 08:16 PM
  #116
69VetteFla's Avatar
69VetteFla
It started
http://forums.corvetteforum.com/c3-g...post1579745099
Old May 4, 2012 | 06:27 AM
  #117
tom00799's Avatar
tom00799
I've owned a number of racing aluminum radiators. Comparatively speaking, the DeWitts radiator costs less but the workmanship and quality is outstanding. The tanks are tig welded to the core and not epoxied like many racing radiators. Epoxied tanks are not durable and are prone to develop leaks in my experience. I needed a radiator in a pinch for my 70 big block automatic. Called Dewitts and was told they did not have one on the shelf. They had it built and shipped within two days. Absolute dead match. Easily dropped 20 degrees in operating temp. I'll put it to the test this summer here in Phoenix when hit hits 110 plus.
To Why DeWitts?
Old May 4, 2012 | 09:55 AM
  #118
gungatim's Avatar
gungatim
reading through your document, why are core leaks only fixable with epoxy? can't it be re-brazed by hand?
Old May 4, 2012 | 11:04 AM
  #119
c3sleeper's Avatar
c3sleeper
Jut a little piece of my dewitts experience and why they truly have the best quality and value product out there.
"Well guys she touched ground and rolled for the first time today and I'll give you a quick rundown...holy s@$! is the only term that seems appropriate ha beautiful loping idle on the bottom end and she just loves to pull!!! Only concerns now are that damn TA bushing that is now very obviously shot to pieces haha. I haven't put a full flogging on her yet but when she hits about 3000 rpm it's time to hold on and say your hail Mary! Incredible power and the center force clutch handles it all very well. A little bity but what clutch wouldn't be concerned the size of the springs in it ha. I cannot say enough about Matt Walsh and all the guys working for the Enginefactory.com crew. This motor looks like a work of art and runs like a bat out of hell! Gotta get that TA fixed tho it's a touch scary to drive with the tail end that loose. Also another shout out to Dewitts radiators. I can't say enough about the quality of their product. On a 90 degree day we idled the car out in the sun with the ac on and the car not moving and the temp never kissed passed 190! Unheard of before the swap and now we are producing a bit more heat with that 10:1 compression ha! Also a great fit when installing and sealing up. The quality of their welds is amazing as is the entire product. Truly a jewel in its own right. Hope to have a video from the passenger seat up soon!"
Old May 4, 2012 | 11:18 AM
  #120
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
I guess it depends on exactly where the leak is. If you punch a hole in a tube when installing the radiator you might be able to flame braze the hole with some of the magic rods they sell. However, aluminum flame brazing looks easy when someone else does it but it never works out that way and it is real easy to make it worse. What the article is referring to is tube-to-header leaks after furnace brazing and you can't really get to those with flame brazing. you would have to flow epoxy in there to get to the leak area.
