question about setting hydraulic valves
Old Aug 26, 2011 | 04:37 PM
  #41
...Roger...'s Avatar
...Roger...
Originally Posted by billla
...but this is not how this is done. The rocker should be loosened until the pushrod rotates freely...then tightened slowly until the first hint of drag is felt...backing off and re-tightening a bit if needed to feel for zero lash.
The push is against the spring...so it's really not going to "back off" after a minute. There's no bleed-down - if the engine isn't running then there's no pressurized oil to push the cup up.
That's where the "experienced" feel of the cup spring comes in.
Some lifters still have oil locked in and some don't.
I think your method might work better for the inexperienced if all rockers were backed off,spin the engine to pump the lifters up and then adjust.
If your talking about adjusting in an un-primed motor , then the person is going to have to feel the cup spring.
Old Aug 26, 2011 | 05:08 PM
  #42
billla's Avatar
billla
St. Jude Donor '14
The cup can't move higher than the top of it's travel, no matter what. If pushed down, even if the lifter has oil in it - the spring will push it back to the top of the lifter. Zero lash will be when the lifter is at the top of it's travel - either by the spring or by any residual oil pressure.
If what you note is happening, then the person isn't feeling for zero lash but is way, way over-tightening...which is pretty hard to do when you're just feeling from a loose pushrod to a hint of friction.
Old Aug 26, 2011 | 05:17 PM
  #43
...Roger...
That's where I think newbies run into a problem, they don't detect that "first hint of drag",then they end up with the lifter cup at the bottom of its travel thinking the bottom is the "drag".
If you or someone experienced were there to point out "the correct point of drag" ,with the cup at the top,I'm sure they would remember it for a lifetime.
I've had many a car towed in with all the lifters bottomed out.
EDIT-Just for the record-I use the spin method.
Old Aug 26, 2011 | 05:24 PM
  #44
billla's Avatar
billla
St. Jude Donor '14
We'll have to agree to disagree - I've never had anyone that's tried it have any difficulties at all...the rod spins loosely, then it starts dragging. Dozens and dozens.
Someone cranking down until they have the lifters flat is someone that has no idea how to adjust valves...regardless of how they find zero lash.
This branding of the twist method as unusable by newbies just doesn't hold water and I have yet to hear anything specific to the contrary. So - do what I did; the next time you're going to help someone with it, talk them through both and see what works. If they actually find the twist method is harder - then post about it
Old Aug 26, 2011 | 05:42 PM
  #45
...Roger...
One of the exercises I remember from HS automotive was setting O lash on a dry lifter,about 1/2 failed it the first time.
The guys that failed ,probably used a set of mics like a C clamp.
Old Aug 26, 2011 | 05:44 PM
  #46
Jeff_Keryk's Avatar
Jeff_Keryk
I grew up pulling wrenches on iron. I over-tighten everything. I sorta-leaned when my brother told me, "How tight do you want it to be the next time you take it off?"
Old Aug 26, 2011 | 06:25 PM
  #47
billla's Avatar
billla
St. Jude Donor '14
I hear that I do a lot of "assisted" builds where the guy wants to build his own engine and I just keep him from making mistakes. It always starts with learning precision measuring...and for some folks...that can take a long, long time.
But my point is newbie does not automatically equal "Bubba".
