question about setting hydraulic valves
Old Aug 26, 2011 | 01:26 AM
tonak's Avatar
tonak
I use the EO/IC and twist. My bet is that the first thing people do when they start the car is listen for clatter. Sooo it's an oft argued approach but I do the adjustment so I can start the car and then use a valve cover with a window cut out so I can adjust the lash with the engine running. That is what has worked for me without fail.
Old Aug 26, 2011 | 04:18 AM
7T1vette's Avatar
7T1vette
To "listen for clatter", the engine would need to be running. There is no need to run the engine when setting hydraulic lifters.
You guys can 'twist'; I can 'twist' or 'shake'; but newbies have trouble with doing the 'twist'. That's just the way it is...
Old Aug 26, 2011 | 07:32 AM
tonak's Avatar
tonak
Oft argued.. didn't know this forum was just for old pros. Just saying what works
Old Aug 26, 2011 | 10:27 AM
billla's Avatar
billla
St. Jude Donor '14
Reopening an old discussion - you continue to state this as "fact", so I assume it has basis: How many people have you, personally, instructed on how to adjust valves within the last 6 months and - having shown them both methods - they found the twist method more difficult?
I've shown 8 - both methods - and all of them had no issue at all with the twist, finding it very simple. Anyone in the Puget Sound, Washington area that wants to be a test subject, drop me a PM
I'm not trying to say one method is "better", though I have my own opinion, but I do challenge this continued contention that twisting is harder for people that haven't done it before given that my experience is exactly the opposite.
Old Aug 26, 2011 | 11:18 AM
7T1vette's Avatar
7T1vette
Billa...
None of those folks had issue with the 'twist' because you were there to physically show them how to do it and explain in detail what to look for. But, you can't do that over the internet. BTW, how many of them could not use the 'shake' method to find "zero lash". If you are honest about it, I would guess that NONE of them had any problem finding zero lash with that method.
We all know that "you know best" on everything you discuss. Why don't we just let the poster try both methods and use the one that works for him?
Old Aug 26, 2011 | 11:44 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
what the hell....i use the method Lars taught us.....use the distributor spark plug tower and mark the tower position on the distributor base and then follow the rotor around adjusting the valves on the cylinder the rotor is pointing to, using the spin method (hydraulic lifters) it was so freaking easy it was embarassing
Old Aug 26, 2011 | 11:52 AM
billla's Avatar
billla
St. Jude Donor '14
These were newbies that I described both processes to - and all of them had no issues with twisting. They typically were well short or well over zero lash for the "shake" method.
You speak for the entire board? So the simple answer is "none"; always easier to attack the person than to answer a simple question that you don't have the answer for.
I noted both ways work - you were the one that noted that the "only" way for a newbie was to use the "shake" method - which is what I challenged and you've stated no basis for.
Same old story...
Old Aug 26, 2011 | 01:51 PM
another-user's Avatar
another-user
well, i just finished cutting out a set of valve covers. if all goes well, ill be able to fire the motor up tonight and check for clatter, and make it to the car show.
Old Aug 26, 2011 | 02:04 PM
tonak's Avatar
tonak
Old Aug 26, 2011 | 02:09 PM
billla's Avatar
billla
St. Jude Donor '14
If you adjusted the valves correctly, there's no reason to cut a pair of covers and listen for clatter...and no reason to adjust the valves while running.
Old Aug 26, 2011 | 02:11 PM
DRIVESHAFT's Avatar
DRIVESHAFT
For some people it is, but consider this....
Every time somebody comes on here and posts about an engine that wont start, or runs poorly after they adjusted their hydraulic lifters, they did it using the spin method.
The purpose of adjusting hydraulic lifters is to remove all up and down slop, and add a bit of vertical preload.
Moving the pushrod in the direction that you are actually adjusting just makes more sense, IMO anyway.
P.S. - I only replied to bobs77vet because it was close to the end of the thread. I'm not trying to argue with Bob.
Old Aug 26, 2011 | 02:12 PM
...Roger...'s Avatar
...Roger...
How about .001 instead of .000 ?
Old Aug 26, 2011 | 02:22 PM
  #33
billla's Avatar
billla
St. Jude Donor '14
This is just simply not the case. Links, please - all of them.
The funny thing is that probably the most common reference here is Lars' paper...which uses the twist method.
Most common issue is that the engine isn't correctly positioned - not that they incorrectly find zero lash.
I don't know why something so simple gets so much pushback...
Old Aug 26, 2011 | 02:29 PM
  #34
bobs77vet's Avatar
bobs77vet
about it being so easy ....i really was talking about using the distributor spark tower markings and following the rotor to adjust the valves....i don't have an opinion on either up/down or spinning what ever the persons fingers can feel, i have done it both ways
Old Aug 26, 2011 | 02:35 PM
  #35
DRIVESHAFT's Avatar
DRIVESHAFT
You really think I bookmarked them all?
In general I dont care how people do it, as long as its working for them.
But every single case that I can remember on this forum and several others where there was a problem involved people trying to find zero lash by spinning the pushrod.
It obviously causes problems for some people.
Old Aug 26, 2011 | 02:36 PM
  #36
...Roger...
i really was talking about using the distributor spark tower markings and following the rotor to adjust the valves....i dont have an opinion on either up/down or spinning what ever the persons fingers can feel.
As Billla says engine positioning is critical.
I wonder if pushing this "0" clearance is a good thing ?
Maybe making sure you have almost 0 clearance is better,surely better than being too tight.
So what if you have .001 or even .002,for gosh sakes your preload ranges from say 1/2 to 3/4 turn,there's aprox. .017 difference there.
This is not brain surgery.
Old Aug 26, 2011 | 02:39 PM
  #37
billla's Avatar
billla
St. Jude Donor '14
Nor do I.
You make the claim again - but nothing to back it up, so...
To question about setting hydraulic valves
Old Aug 26, 2011 | 03:14 PM
  #38
...Roger...
Nor do I.
I gotta tell you guys something funny but first.....
I think the "spinning" is misunderstood by first-timers , I think they believe that at .001 the rods spins and at .000 the rod spins and a tiny bit more the rod locks up solid,which is where I think the problem is.
When in reality if you go a tiny bit tight and wait a few seconds the rod will spin again just not as freely as it should and the spinning is turning , not spinning freely.
I went to the garage to make a little video of exactly what I'm saying above,I took it to 0 free spinning ,I turned the nut a little further and the rod became very hard to turn,I waited for a few seconds thinking it would turn fairly easy,it didn't what the heck, scratching my head, .............. dang motor has solids in it.
Looking back at the video I have this WTF look on my face.
Old Aug 26, 2011 | 03:17 PM
  #39
DRIVESHAFT's Avatar
DRIVESHAFT
Yep. Them solids take a Loooooooooooong time to bleed down.
Old Aug 26, 2011 | 03:57 PM
  #40
billla's Avatar
billla
St. Jude Donor '14
...but this is not how this is done. The rocker should be loosened until the pushrod rotates freely...then tightened slowly until the first hint of drag is felt...backing off and re-tightening a bit if needed to feel for zero lash.
The push is against the spring...so it's really not going to "back off" after a minute. There's no bleed-down - if the engine isn't running then there's no pressurized oil to push the cup up.
