82 fuel injectors
Old Aug 27, 2011 | 02:10 PM
leebay's Avatar
leebay
Default 82 fuel injectors
Do the fuel injectors on a 82 spray continuous ? I just checked out my injectors with a noid light and both are spraying but not continuous while the car is running. The car runs for about 3 seconds and nearly dies until the injectors start spraying again. Acts like its starving for fuel. I have a new fuel pump that i am going to install in a few days.
Thanks for your help.
Old Aug 28, 2011 | 02:59 PM
Wrecked82's Avatar
Wrecked82
They pulse, but the pulse is fast and continuous.
Old Aug 28, 2011 | 04:53 PM
7T1vette's Avatar
7T1vette
Sounds like you have a problem. Are you getting any trouble codes? (Does the Check Engine light work?)
Old Aug 28, 2011 | 07:26 PM
leebay's Avatar
leebay
Yes, check engine light goes off and on, I did a code check and had code 22 so i replaced the Throttle Response Sensor and cleared the code but it came back on. I have not yet set the TRS with the volt meter. Car was running fine even with the check engine light on until last week . I am going to replace the fuel pump, sock and fuel filter .
Thanks for your reply
Old Aug 28, 2011 | 08:26 PM
terry82's Avatar
terry82
when you replace the throttle postion switch try for .525 you can get a lot of info from herehttp://crossfireinjection.net/
Old Aug 29, 2011 | 09:30 AM
Wrecked82's Avatar
Wrecked82
Your voltage could be anywhere. Imperative you set it within range. Code 22 means too low, I think. Code 21 too high.
To 82 fuel injectors
