Rear Spring Adjustment
Old Aug 29, 2011 | 11:09 PM
andycw's Avatar
andycw
Default Rear Spring Adjustment
Hello All,
Just finished restoration of the rear end of my 69 and need some help. It has the fiberglass spring. How do I adjust the tension on the spring and what is the proper ride height etc? I realize I can loosen or tighten the spring bolts but I don't know how much or how little. Do I need to have the wheels elevated to do this?
Thanks,
andy
Old Aug 29, 2011 | 11:21 PM
wombvette's Avatar
wombvette
The spring tension will not adjust. The only thing you can do is shorten or lengthen the bolt to raise and lower the vehicle. Really don't matter whether its off the ground or not, but you will have to let it down and roll it to tell what you did.
Old Aug 30, 2011 | 05:50 PM
Alan 71's Avatar
Alan 71
Hi Andy,
You asked about ride height too.
In the front of the AIM there's a sheet for "TRIM HEIGHTS", in my 71 AIM it's UPC 0, Sheet A-12.
An easy one to check is the dimension from the ground to the center of the rear wheel arch. About 28".
The size (height) of the tires affect this dimension. It's based on F-70 tires which were about 27" tall.
Regards,
Alan
Old Aug 31, 2011 | 12:47 PM
andycw's Avatar
andycw
Default Thanks
Thanks for the info.
Old Sep 2, 2011 | 06:40 AM
3X2's Avatar
3X2
Using a small level, I adjusted mine so the half shafts are parallel to the ground with 1/2 tank of fuel.
To Rear Spring Adjustment
