Well, you have to start touching something. Bad gas? Freshen the HEI distributor components. If you still have the Q-jet , check to see if the float is sinking, some cheap ones soak up fuel and sink. Have the plug wires been replaced? Just start freshening up everything - it's a Corvette, you'll love it when it's running right.
Advanced the timing to about 18 deg btdc and it seems to be running much smoother and better response. i feel i may be able to advance it a little further without pinging.
Still have a big hesitation when i stomp on the gas pedal (vacuum leak) and will sort that out when i change the manifold.
