I am in the process of installing a pair of headers. Since I have the original manifolds off now,(waiting for the headers to arrive) I figured I might as well change the plugs since there real easy to change now. I took one out to see what I had = AC DELCO R45TS. should I replace these with another type? Hot/Cold. I know to gap them at 45. I have a 77 L-48 with advanced timing, dual exhaust, my carb. has been tuned, and breaths better.
Generally speaking...
Hotter plugs are best in a low compression / low performance engine to burn off combustion deposits.
Cooler plugs are better in high compression / high performance engine.
Thanks, so are the one's I have in there the right one's?
Also, any advantage of running the wires on top? I prefer to keep them hidden like the factory. But I see so many replacing the long one's with short one's running on top.
Hey Dave. R45TS are the correct ones. On the wires I think it will depend on the clearance you will have between the wires and the ends of the wires. They get real close on some of the cylinders. I am sure someone will have pics. mike...
Thank you guys. I just took the shields off that covered the plugs. I was going to clean them up. Put got to thinking, I don't remember seeing any with headers. Do you leave them off when putting headers on? I assume they are there for protection from heat. So I would believe it's wise to place them back on. What are your thoughts on this?
Over the top!
You won't need the shielding with headers but save the pieces and the cast iron manifolds.
You may need it someday.
Two stock wires go through the boomerang on each side on a stock set up, it's a real test of ability and patience, I'm sure other will post some over the top suggestions.
I am running long headers on my 71 and have the wires running underneath. I used the factory looms but did not use any of the shields and I am not sure they would fit.
Getting the headers on was not at all hard. The hard part was getting the headers to connect to my exhaust. Post a few photos if you can I know you have done a lot of work on your car this year.
I have to agree with the over header wire looms since it is really close trying to go underneath with the factory set up with the way most header tubes are bent. I used some looms similar to the photo wcsinx posted since they follow the base of the valve cover which still looks clean.
