Weird Distributor/Idle Problem
Old Aug 31, 2011 | 06:22 PM
ted13b's Avatar
ted13b
Default Weird Distributor/Idle Problem
Over the weekend I installed an new Accell dist in my 77 L48. I set the base idle at 16 degrees and the car ran great. Then I remembered that I hadn't reconnected the vac line to the vac advance. When I did, the car idled rougher, with a slight misfire every few seconds. It has an adjustable vac canister, so I tried everything from all the way in to seven turns out, and it still idles better with the vac advance disconnected. Any ideas?
Old Aug 31, 2011 | 07:05 PM
SH-60B's Avatar
SH-60B
A leaky hose or ruptured advance diaphram. 16 degrees static advance seems like alot, I would think more like 12 degrees max.
What is the timing at idle with the vac advance connected?
Old Aug 31, 2011 | 09:07 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
try moving from ported to unported vacuum or vice versa.
Old Aug 31, 2011 | 09:58 PM
DRIVESHAFT's Avatar
DRIVESHAFT
The combination of your initial timing and the vacuum advance is giving you more advance at idle than the engine wants.
In order to run manifold vacuum to your vac advance, you may need to run less initial advance.
Old Sep 1, 2011 | 11:45 AM
ted13b's Avatar
ted13b
Thanks for the help guys, I figured it out. My dial-back timing light was set improperly, my timing was actually set at 20 degrees. I cranked it back and all is good now. thanks.
Old Sep 1, 2011 | 12:03 PM
falconview's Avatar
falconview
depending on the type timming gun you have a you may be able to set the timming with the vacume hose connected.
Old Sep 1, 2011 | 02:48 PM
63split63's Avatar
63split63
Can you explain .
Bill
Old Sep 2, 2011 | 10:22 AM
falconview's Avatar
falconview
If you have a timming light with a built in advance dial you check timing with the vacume to your dist. Set the dial to the timing you want and rotate the dist until the mark lines up to 0 on at you crank. This is good to within 2 degrees before or after TDC.
To Weird Distributor/Idle Problem
