I own a 1976 Corvette and i need to know "How To Remove The Power Window Switches " loacted the the brake counsel. Do you pry the switch fron the power source? Does the switch unplug?
I do not want to destroy any on the components.
Please advise. Thanks you for any assistance offered.
If it's like the 80, there is a screw on each end holding it in place. Remove it,then pull off the electrical connector which just plugs over some prongs on the underside of the switch.
