A/C removal
Old Apr 30, 2002 | 05:16 PM
Ryan77's Avatar
Ryan77
Default A/C removal
I'm in the middle of a cam swap and I am also removing the a/c since it doesn't work anyway. The compressor and condensor are already out, but what else do I need to remove/change? Thanks in advance.
Old Apr 30, 2002 | 05:22 PM
One GM A Tech's Avatar
One GM A Tech
Default Re: A/C removal (Ryan77)
If your in the process of pulling everthing out then you still have the accumulator and the evaporator to go. :cool:
Old Apr 30, 2002 | 07:54 PM
jsimpson's Avatar
jsimpson
then just ship it all to me to keep from cluttering up your garage!
Old May 4, 2002 | 08:56 PM
Ryan77's Avatar
Ryan77
Default Re: A/C removal (jsimpson)
jsimpson-- I'll give first pick on what I have
Old May 4, 2002 | 11:08 PM
Tom77's Avatar
Tom77
I'm in the process of putting my air back together. Got the parts Friday. Got to have the Air. :yesnod:
Old May 4, 2002 | 11:55 PM
SharkAttack's Avatar
SharkAttack
If you want the car to run a little cooler and remove any and all excess weight associated with the A/C, remember the consdensor core and evaporator (in front of the radiator). I pulled an entire system from my '71 without removing the hood (or scratching the paint).
Since you may change your mind or sell the car some day (you never know), be sure to keep all bolts, washers, o-rings, etc.
Old May 5, 2002 | 11:34 AM
a1parrothead's Avatar
a1parrothead
You and I are on opposite ends of the spectrum. I just installed a new pump and did some hose modifacations. Nice and cold A/C :) I really need it in the climate I am in!
Old May 5, 2002 | 03:27 PM
Geoff1340's Avatar
Geoff1340
Are there any aftermarket providers of A/C systems? Previous owner gutted A/C from my 77 and I too would like KOOL air....
Old May 5, 2002 | 05:18 PM
jsimpson's Avatar
jsimpson
Default Re: A/C removal (Geoff1340)
Vintage air makes aftermarket setups for C-2's, but not C-3's. Stock air can be made to keep your car VERY cool. Just do a search and load up on info.
To A/C removal
