Rebuilt calipers a few months ago. pulls to the left when braking.Not really too noticeable except when you take your hands off the wheels.
What can be the cause(s) of this.
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
I had the same issue with my 82. The PO replaced the left caliper and not the right. I believe in replacing them in pairs. It keeps everything on an even keel.
Also check rotor thickness. If one is thicker than the other, this could cause it to pull slightly. Did you replace both rotors as well? Who rebuilt your calipers. I got a set many years ago where one of the pistons wasn't traveling (for lack of a better word) "smoothly" in the bore, and that was causing issues.
Ed
All rebuilt calipers were from VBP but rotors were not touched.
From: Where it's always hot as Hell-South Louisiana.
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
check fluid flow thru ur front right flex hose. Pull the hose off, blow thru it with compressed air. Same happened to me once, the flex line had broken down rubber inside restricting the flow. If found, replace with new lines (4) for all corners .
