v-6 t-5 wc trans
Old Sep 5, 2011 | 02:33 PM
pawpaws toy's Avatar
pawpaws toy
Default v-6 t-5 wc trans
I have been considering replacing my bw t-10 with a t-5. Looking at different sites, it seems that starting in 88 the F body V6 T5 was upgraded to WC specs. The lower 1st. gear ratio they have would help with my 3.08 rear. Any thoughts?
Old Sep 5, 2011 | 03:04 PM
694speed350's Avatar
694speed350
wouldn't use a v6 transmission in a v8 car.
Old Sep 5, 2011 | 04:00 PM
cv67's Avatar
cv67
St. Jude Donor '05
Youll pop that trans right away dont even bother
Old Sep 5, 2011 | 07:11 PM
Garys 68's Avatar
Garys 68
Just to add to that the v6 actually has the ford trans to bell housing pattern.
Old Sep 5, 2011 | 07:13 PM
sakins.02vert's Avatar
sakins.02vert
I would go with a WC T-5 out of a V8 at a minimum.
Old Sep 9, 2011 | 10:24 AM
pawpaws toy
I wonder if a GM V6 bellhousing would work instead of using an adapter?
Old Sep 9, 2011 | 05:58 PM
WTFizzit's Avatar
WTFizzit
The following info is based on "IIRC"
The '88-92 V8 T5s were WC, the V6 boxes went WC '93 and later----no T5s behind V8s after '92
The tranny-to-bellhousing mounting bolt pattern went to Ford style in '93
The bellhousing (to engine) mounting bolt pattern is different from V6 to V8, unless the V6 was a 4.3
The V8 boxes had higher torque ratings than the V6 units, but the max for the GM V8 T5 was only somewhere around 300lb/ft-----probably why they were never matched to anything bigger than a 305
I strongly suggest you research these issues further. If anyone else knows fer-sure differently by all means jump in and correct me.
Old Sep 12, 2011 | 08:13 PM
pawpaws toy
You're right. I was looking for a low-buck way for a good T-5 conversion but this is not it.
To v-6 t-5 wc trans
