Rock guard?
Old Sep 6, 2011 | 07:51 AM
Valley Vette's Avatar
Valley Vette
Veteran: Canadian Forces
Default Rock guard?
Greetings,
I'm told that the "patches" just behind the door and in front of the wheel well on the lower part of the rear quarter panel are add-ons to protect from rock damage, etc. The one on the passenger side is cracked.
Has anyone ever seen these before? And how can the damage guard be repaired or replaced?
Old Sep 6, 2011 | 10:44 AM
MelWff's Avatar
MelWff
http://www.ecklerscorvette.com/corve...1968-1982.html
Old Sep 6, 2011 | 12:15 PM
7T1vette's Avatar
7T1vette
Or, Cleartastic; or, CrystalEdge
Old Sep 6, 2011 | 04:51 PM
Valley Vette
Thanks. The wording of the ad at the link leads me to believe that that product is more of a tape while these appear to be made of either plastic or fiberglass material - thus they have an ability to become "chipped" and "cracked" themselves. Nonetheless they appear to be intended to perform the same guard function. The next trick will be to decide how best to repair/remove/replace these without causing damage to the body and paint below. And it appears that they may have been added before the last paint job.
As always, your comments and suggestions are very much appreciated. No need to lean everything the hard way...
VV
Old Oct 18, 2011 | 07:53 PM
TKO Performance's Avatar
TKO Performance
Premium Supporting Vendor
Active Streak: 90 Days
From: ★ Performance Parts & Accessories ★ 1800 778 9898
St. Jude Donor '07-'08-'11-'12-'13-'14-'15-'16-'17
Way late but I just noticed this post. After the repair and the paint is cured, you might want to look into Cleartastic "dog leg" paint protectors.
Its the only clear film that has NO adhesive!
You apply it yourself. Removable and reusable. Invisible once applied.
http://store.cleartastic.com/68frofrewhki.html
And while your at it...
http://store.cleartastic.com/74berewhprki.html
Good luck
Thank you
Ed
Old Oct 21, 2011 | 06:23 AM
Valley Vette
Good luck
Thank you
Ed
Ed,
never too late! Thanks for the info.
VV
To Rock guard?
