how much to fix door locks?
Old May 1, 2002 | 12:48 AM
bkirk's Avatar
bkirk
Default how much to fix door locks?
'bout how much are power door locks to repair on an '81?
Old May 1, 2002 | 09:22 AM
rmadlem's Avatar
rmadlem
Default Re: how much to fix door locks? (bkirk)
It depends on what the problem is. New lock switches are about $45, or Pep Boys has generic ones for $19.95. The plug that goes on the back of the switch is about $12 from Ecklers, etc.
And remember, if one lock switch is bad, the other won't work either.
What problem are you having??
Old May 1, 2002 | 09:28 AM
bkirk's Avatar
bkirk
Default Re: how much to fix door locks? (rmadlem)
both are dead. that's about all i can tell you.
Old May 1, 2002 | 09:47 AM
rmadlem's Avatar
rmadlem
First thing to check is if any of the wires came off the plug connector on the back of the switch. This is pretty common as the wires get a little brittle. If this is all it is, then it's just a matter of reconnecting the wires...or buying the rebuild harness for $12.
Old May 1, 2002 | 07:02 PM
corvgreg's Avatar
corvgreg
Emerging Vendor
My power locks will "lock" but not "unlock"...haven't had a chance to look into this...probably the switch?
Old May 1, 2002 | 07:37 PM
Mike69@ECS's Avatar
0Mike69@ECS
Former Vendor
Cruise-In III Veteran
Cruise-In V Veteran
Default Re: how much to fix door locks? (corvgreg)
Did you check the fuse???
Old May 1, 2002 | 07:57 PM
Chris Fowler's Avatar
Chris Fowler
Cruise-In IV Veteran
St. Jude Donor '03-'10
When I got my car neither of the power locks worked. When I flipped the switch I would hear a noise, but nothing would move...
I took the door panel off and sprayed every joint I could see with carb cleaner, then a WD-40 like lubricant and then a silicone spray. I also made sure to get a bunch of the lubricant down into the door lock actuator.
Both locks work perfectly now.
To how much to fix door locks?
