serpentine question
Old Sep 9, 2011 | 08:21 AM
gator79's Avatar
gator79
Default serpentine question
is there a serpentine setup that will work with a stock big block hood? I have a 71 with a 454.
Old Sep 9, 2011 | 03:50 PM
LB66383's Avatar
LB66383
Check March Performance (marchperf.com).
Old Sep 9, 2011 | 11:03 PM
gator79's Avatar
gator79
they have a nice sysyem, anyone used it with the stock big block hood?
Old Sep 9, 2011 | 11:27 PM
gcusmano74's Avatar
gcusmano74
I wonder if you could find a big block pickup, van or something in a boneyard with a serpentine setup, and use or copy that?
Old Sep 10, 2011 | 12:14 AM
Ray Y's Avatar
Ray Y
I used a MillerSpeed system. I love the 1" wide cogged Gilmer belt set up he specs and it worked great on my '70 BB.
Contact Alistair@MillerSpeed.com or 310-408 8798 and tell him I said Hi.
Ray Y
Old Sep 10, 2011 | 12:21 AM
toddalin's Avatar
toddalin
Ray Y
Old Sep 10, 2011 | 12:48 AM
Ray Y's Avatar
Ray Y
Oh Yeah!!!
Hey Todd yours turned out great. I don't remember seeing the finished pics before, it looks fantastic!! & I bet you've never slipped/squealed the belt!
Old Sep 10, 2011 | 07:14 AM
Zychron's Avatar
Zychron
Here is some info from a few guys that have adapted SB serpentine to BB:
http://www.vettemod.com/forum/showth...tes+serpentine
Old Sep 10, 2011 | 08:13 AM
gator79's Avatar
gator79
thought about that but it wont clear the hood
Old Sep 10, 2011 | 11:14 AM
iree75's Avatar
iree75
The march system will clear the hood no issue.. not inexpensive, but what on a corvette is?
Old Sep 11, 2011 | 10:05 PM
71rdster's Avatar
71rdster
I can't say for certain, but I believe most OEM setups for big block pickups etc would use a long waterpump. I think that would cause some interference issues with the crank pulley and the frame in a Vette application. March, Zoops, or other aftermarket suppliers may be the better bet.
Old Sep 13, 2011 | 10:09 PM
tekvette's Avatar
tekvette
I recently bought a ConceptOne serp. system. I don't think it gets more compact than this.
Old Sep 14, 2011 | 12:15 AM
Curby's Avatar
Curby
Cruise-In VII Veteran
St. Jude Donor '06
Street & Performance has a "Vette" big block set-up for A/C and power steering. It is a beautiful system and MUCH less expensive tham a March or Concept One system. They build their own stuff and trim the excess tabs off of the Sanden compressor, use rear connections and clock the alternator or use the later model alternator.
These guys are great to work with, too.
http://www.hotrodlane.cc/
Go to their online catalog, then to page 122 for the "BBC Vette" system. You can find prices and such on pages 119 and themn read the notes for the other parts like the alternator and the reverse rotation water pump.
Old Sep 14, 2011 | 04:10 AM
Gale Banks 80''s Avatar
Gale Banks 80'
Vintage Air works in a Vette with the Smallblock and I think somebody here has done it with a Bigblock. Worth a look.
Old Sep 14, 2011 | 10:08 AM
mysixtynine's Avatar
mysixtynine
Default Vinatage air front runner
Here is my front runner.
I had to notch my cross member and am using a dewitts radiator and electric fans. I also added a power steering pump.
It should fit under your hood no problem.
Old Sep 14, 2011 | 06:40 PM
Tony Rags's Avatar
Tony Rags
I'm putting on a Vintage Air Front Runner also to my 454 small block. Had to slightly notch the front cross member, but this setup is BY FAR the most compact, the best looking, and the highest quality I have ever seen.
Old Sep 14, 2011 | 06:42 PM
Corey_68's Avatar
Corey_68
I have a March system on my 468 that I'm removing (installing a LS2/6speed) and according to them it will fit under a stock BB hood, I have a L88. March system will be going up for sale and the car will be in South Louisiana if interested in the system.
[img]
To serpentine question
Old Dec 16, 2012 | 11:11 PM
gator79's Avatar
gator79
Default update
I have not worked on the car in four years but just recently got back on it. I bought the march system for big block corvettes. no frame modification needed. it uses two belts. here are a few pics of the install, I finished it yesterday and it works fine. I need to take finished pictures
Old Jan 1, 2013 | 03:23 PM
gator79's Avatar
gator79
Default install completed
here is the finished product.
clearance of the front crosmember
the power steering reservoir is from summit racing I had to fab a bracket and mount it to the head
Old Jan 2, 2013 | 10:48 AM
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
Good to see you back on the vette and forum,
I had not seen any posts from you in a while,
The serp setup looks great,
That is the same reservoir I have on mine,
Be careful with those SS lines rubbing on metal parts, the braid will break and the inner liner will rupture causing a mess (dealing with that right now).
Curious if that reservoir has a small internal Tee fitting (distribution fitting) on the return line?
Neal
