serpentine question
Old Jan 2, 2013 | 10:24 PM
briankeery's Avatar
briankeery
That setup looks really trick.....good call.
Old Jan 2, 2013 | 10:41 PM
gator79's Avatar
gator79
Originally Posted by chevymans 77
Good to see you back on the vette and forum,
I had not seen any posts from you in a while,
The serp setup looks great,
That is the same reservoir I have on mine,
Be careful with those SS lines rubbing on metal parts, the braid will break and the inner liner will rupture causing a mess (dealing with that right now).
Curious if that reservoir has a small internal Tee fitting (distribution fitting) on the return line?
Neal
yes I got burnt out and bummed out when the paint started to freak out on me so it sat in the shop corner for 5 years untouched. I built several other cars and trucks in the mean time. I recently got fired up about finishing it and hope to be on the road this summer. thanks for the tip I will make sure those hoses are not touching anywhere, mine has a fitting on the inside with holes drilled in the side to control the return pressure.
Old Jan 2, 2013 | 10:43 PM
gator79's Avatar
gator79
thanks, the actual reason for the serpentine setup is that I could never get the factory belts to line up correctly. this solved that problem
Old Jan 2, 2013 | 11:20 PM
AGVI's Avatar
AGVI
Canadian Events Coordinator
Looks really good!!!
