Cool engine down at the strip?
Old May 1, 2002 | 10:01 AM
C3Vettesrock's Avatar
C3Vettesrock
Default Cool engine down at the strip?
Whats the best way to cool down the engine at the drag strip while waiting in line?
Old May 1, 2002 | 11:11 AM
BSiegPaint's Avatar
BSiegPaint
St. Jude Donor '06-'07
Default Re: Cool engine down at the strip? (C3Vettesrock)
I always used a Hudson pump-up sprayer (like for weed killer - get one at Home Depot) full of water and while the car was idling, sprayed the radiator with a cool mist for a few minutes. If you're concerned about spots on your engine chrome, don't do this! It really throws a bit a spray all around, as you can imagine - but it did the trick for me.
Old May 1, 2002 | 11:25 AM
ylose's Avatar
ylose
Default Re: Cool engine down at the strip? (BSiegPaint)
hood up while waiting....vettes get toasty under there... :yesnod:
Old May 1, 2002 | 11:30 AM
Wrencher's Avatar
Wrencher
On the GTO I used to race, I had an electric fan mounted on the front of the radiator. it was hooked to the key (it also had a seperate switch to de-activate it entirely), so I'd just pull into the lanes and put the key in accessory and the fan would cool down the radiator while I waited. Worked for me.
Hans
Old May 1, 2002 | 11:37 AM
Corey_68's Avatar
Corey_68
Default Re: Cool engine down at the strip? (Wrencher)
You could always put liquid nitrogen on your intake and freeze it??!! :lol:
Actually I had a guy tell me his friend use to do this?? :confused:
To Cool engine down at the strip?
