Wrong rear caliper ?
Old Sep 9, 2011 | 05:25 PM
boltnut's Avatar
boltnut
Default Wrong rear caliper ?
My manual has an exploded view of the brake caliper that shows two O rings and also states there should be two to replace. The caliper I just took off to rebuild only has one O ring on the rear side of the caliper. Is this the wrong caliper ?
Old Sep 9, 2011 | 07:06 PM
MelWff's Avatar
MelWff
Only the fronts have 2 O rings, rears only 1. Probably related to the 2 bleed screws on rear and additional passage not necessary.
Old Sep 9, 2011 | 07:24 PM
boltnut's Avatar
boltnut
ok. the manual (at least where i read ) did not specify. i guess my caliper is good to go. there is only one passage machined. the other side is blank. thanks !
Old Sep 9, 2011 | 09:03 PM
boltnut's Avatar
boltnut
can i slide the pistons back in without the "special' tool ?
Old Sep 10, 2011 | 11:39 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Sliding them back is not the problem; keeping them back and out of the way is what the clipper is for.
Install the pads, push them back, slip a socket between the pads to hold them, install the caliper on the rotor. Socket will slip out as the caliper goes on.
Go find the socket when it rolls away.
Old Sep 10, 2011 | 12:01 PM
'75's Avatar
'75
I've got some wood blocks for that purpose.
Old Sep 10, 2011 | 02:35 PM
boltnut's Avatar
boltnut
Thanks. Used a 5/16 socket and it worked perfect. Funny thing is that I was talking about sliding the pistons back in the ss sleeves after replacing the seals. I found the thread about using a feeler gauge. Caliper rebuild went well ( only had to buy two kits after messing up the first) and now I have a good pedal feel again. Im sure I can do better but I'm going to drive it a little and then bleed again.
Old Sep 10, 2011 | 03:52 PM
...Roger...'s Avatar
...Roger...
Great , glad you got to the bottom of it.
Old Sep 10, 2011 | 04:03 PM
boltnut's Avatar
boltnut
yeah, for a guy that is on the fence about wanting to do all this work for the joy of C3 ownership, having a success was a big deal. it feels good.
Old Sep 10, 2011 | 05:06 PM
...Roger...
You whipped one of the trickiest,hopefully the next few problems won't be so difficult.
To Wrong rear caliper ?
