Holley transfer slots
Old Sep 9, 2011 | 06:00 PM
Dantana's Avatar
Dantana
Default Holley transfer slots
I've been through Lars' papers to adjust my 670 Street Avenger several times and best I can tell my butterflies are stuck or I'm trying to adjust the wrong thing. I thought the transfer slots were the long slots that run up the bore. As you can see I have my idle screw backed all the way off and the butterflies won't close anymore to achieve the .020" adjustment position. I'd estimate them currently at .125" or so. What am I doing wrong? Are those not the right slots?
Old Sep 9, 2011 | 06:59 PM
MelWff's Avatar
MelWff
They are the correct slots. Something else in the linkage is preventing the blades from fully closing. Was you choke fully open when you took this picture? Is the fast idle cam preventing full closure?
Old Sep 9, 2011 | 07:09 PM
Dantana's Avatar
Dantana
choke - when i pushed the red choke cam(?) all the way to lock it open they closed right up.
Thanks!
Old Sep 9, 2011 | 07:12 PM
MelWff's Avatar
MelWff
Glad that helped
Old Sep 9, 2011 | 07:29 PM
scottyp99's Avatar
scottyp99
I have scratched my head over the exact same thing. Here is what is most likely going on: When you are making this adjustment, you are most likely holding the carb upside down, looking down at the bottom of the baseplate to observe the transfer slot. While it is upside down, the weighted end of the fast idle cam flops down and holds the throttle plates open. Flip the carb over right side up, hold the choke flap all the way open, and give the throttle linkage a little flick, and the throttle plates should close up all the way. Then flip it over again and observe the transfer slot. Ya have to know what you are doing when you adjust things like carburetors. Like my Dad always said, "If you don't want to pay an expert, ya have to become an expert." You are now one small step closer to being a Holley carb expert!
Scott
Old Jul 14, 2012 | 01:50 PM
Grumpy 427's Avatar
Grumpy 427
Just went through the same thing, thanks for this thread.
Old Jul 14, 2012 | 05:16 PM
gkull's Avatar
gkull
Your carb is upside down for the measurement.
Look down the barrels when mounted to look at the slots
You also want the front and rear nearly the same so it draws off all 4 at idle
Old Jul 23, 2012 | 04:58 AM
gkull's Avatar
gkull
did you ever get this going?
To Holley transfer slots
